Anonymous
how to connect a brocade 3800 and 5000 switch?
How to connect a brocade 3800 and 5000 switch? How setup the PID on brocade 3800. Ater change PID on 3800 switch, the host an AIX OS computer how setup ? Thanks
External Moderator
Re: how to connect a brocade 3800 and 5000 switch?
wich exact FOS Release is loaded in the 5000 switch
FOS 3.2 work with some restriction, see follow example with FOS 6.2
1 All zoning and fabric operations performed in a fabric with products running older versions of FOS should be done via interfaces to products running the latest version of FOS. This is particularly important for Brocade 3XXX series switches that do not support zoning configuration for newer products.
6 Products operating with FOS versions less than v5.3.1b or v6.1.0e may not participate in a logical fabric that is using XISLs in the base fabric.
9 These platforms may not be directly attached to hosts or targets for encryption flows.
TechHelp24
