Anonymous
how do I make an ISL connection between 2 brocade 5100 switch ?
Hello,
I have created a fabric of two SAN switches Brocade 5100 (Switch1 and Switch2). When I tried to create the aliases, I found that the Switch1 doesn’t see any of the ports of Switch2.
The domain ID of the 2 switches are different and the licenses are entered correctly (Fabric, Zoning, Trunking..) but when I enter in the zoning’s tab I only see the ports under Switch1 domain ID. (See attached files please)
The WWNN of all devices connected to the 2 switches are visible but the ports under the second domain ID aren’t.
In that case I can’t use hard zoning.
Could you please help me
Thank you
Anonymous
Re: how do I make an ISL connection between 2 brocade 5100 switch ?
Attached files??
Login to the switch via telnet/ssh and provide the o/p of following
switchshow
fabricshow
islshow
Anonymous
which FOS both the SWs have. use fabstatsshow , have you merged the SWs. switchshow, islshow, trunkshow, fabricshow, see the outputs of these cmnds.
what are the ways you have performed to merge the SWs?
Anonymous
The web tools functionality are moved to DCFM
Anonymous
Yes 6.2 onwards.
Anonymous
Yes it's right and there are severals functionalities concerning zone configuration
Thank you :)
