Anonymous
hello ,I have problem 8 Gb/s
I have problem with switch brocade 300 for link  8Gb/s .
I have two switch brocade 300 are connect to 8GB/s with short _dist ( 220 m , 50 /125  )  end other two switch brocade 300 are connect to 4GB/s with short _dist ( 220 m ) !!  .
I have change  port  , change  SFP , change cable , but the link don't take 8 Gb/s .
Can you help me ??
best regards
INFORMATION
brocade  SLKWRM 300
fabric OS 6.4.2a
port SFP
vendor name = brocade
Vendor OUI = 00:05:1e
Distance shout_dist
Valued Contributor
Re: hello ,I have problem 8 Gb/s
Hi,
Please, attach the output of the following command in the 4 swiths:
sfpshow <port> -f
portcfgshow <port>
maybe you're using 4Gb SFPs or might be the cable... have you tried to force the ports to 8G?
Rgds
Anonymous
Hi ,
I don't try force ports to 8Gb /s
this is output command for Fabric 1 and Fabric 2
Fabric 1 is  8 Gb/s
IP switch 192.168.105.133
Port  0: id (sw) Vendor: BROCADE          Serial No: UAF4120300017W9  Speed: 200,400,800_MB/s
F1_T1_DID11:admin> sfpshow 0 -f
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 540c404000000000 200,400,800_MB/s M5,M6 sw Short_dist
Encoding:    1    8B10B
Baud Rate:   85   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  5    (units 10 meters)
Length 62.5u:2    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-1000117-01
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Date Code:   120121
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x30
Alarm flags = 0x0, 0x0
Warn Flags = 0x0, 0x0
                                          Alarm                  Warn
                                      low        high       low         high
Temperature: 35      Centigrade     -10         90         -5          85
Current:     7.750   mAmps          1.000       17.000     2.000       14.000
Voltage:     3270.3  mVolts         2900.0      3700.0     3000.0      3600.0
RX Power:    -4.2    dBm (376.0 uW) 10.0   uW   1258.9 uW  15.8   uW   1000.0 uW
TX Power:    -3.3    dBm (469.3 uW) 125.9  uW   631.0  uW  158.5  uW   562.3  uW
F1_T1_DID11:admin> portcfgshow 0
Area Number:              0
Speed Level:              AUTO(HW)
Fill Word:                2(SW Idle-Arbff)
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                AE
Port Auto Disable:        OFF
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
Fault Delay:              0(R_A_TOV)
NPIV PP Limit:            126
CSCTL mode:               OFF
Ip switch 192.168.105.190
F1_M_DID9:admin> sfpshow 0 -f
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor PN:   57-1000012-01
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   UAF11039000194A
Date Code:   100922
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x30
                                          Alarm                  Warn
                                      low        high       low         high
Temperature: 43      Centigrade     -10         90         -5          85
Current:     8.972   mAmps          1.000       17.000     2.000       14.000
Voltage:     3258.7  mVolts         2900.0      3700.0     3000.0      3600.0
RX Power:    -6.3    dBm (235.7 uW) 10.0   uW   1258.9 uW  15.8   uW   1000.0 uW
TX Power:    -3.3    dBm (467.7 uW) 125.9  uW   631.0  uW  158.5  uW   562.3  uW
F1_M_DID9:admin> portcfgshow 0
Area Number:              23
Fill Word:                0(Idle-Idle)
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                AE
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
NPIV PP Limit:            126
CSCTL mode:               OFF
this is output command Fabric 2 , it is 4 Gb/s
192.168.105.134
F2_T1_DID22:admin> sfpshow 0 -f
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   UAF1103900018WZ
Date Code:   100922
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x0
F2_T1_DID22:admin> portcfgshow 0
Area Number:              0
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                AE
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
NPIV PP Limit:            126
Ip switch 192.168.105.191
CSCTL mode:               OFF
                                          Alarm                  Warn
                                      low        high       low         high
Current:     7.584   mAmps          1.000       17.000     2.000       14.000
Voltage:     3290.9  mVolts         2900.0      3700.0     3000.0      3600.0
RX Power:    -4.4    dBm (366.1 uW) 10.0   uW   1258.9 uW  15.8   uW   1000.0 uW
TX Power:    -3.3    dBm (471.9 uW) 125.9  uW   631.0  uW  158.5  uW   562.3  uW
F2_T1_DID22:admin>
F2_M_DID10:admin> sfpshow 0 -f
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   UAF110310000LM4
Date Code:   100727
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x0
                                          Alarm                  Warn
                                      low        high       low         high
Temperature: 42      Centigrade     -10         90         -5          85
Current:     8.602   mAmps          1.000       17.000     2.000       14.000
Voltage:     3295.1  mVolts         2900.0      3700.0     3000.0      3600.0
RX Power:    -4.4    dBm (362.2 uW) 10.0   uW   1258.9 uW  15.8   uW   1000.0 uW
TX Power:    -3.3    dBm (462.4 uW) 125.9  uW   631.0  uW  158.5  uW   562.3  uW
F2_M_DID10:admin> portcfgshow 0
Area Number:              23
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                AE
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
NPIV PP Limit:            126
CSCTL mode:               OFF
thanks you
Contributor
8Gbps license installed ?
Anonymous
Hi ,
How can I check ?
thank you
External Moderator
First, DCX not required any xGb License, and second Brocade 300 is 8Gb Native.
TechHelp24
Anonymous
Hi ,
other ports are 8 Gb/s .
thank you
Contributor
Hi Antonio,
            You are right. Why I wanted to ask ? - I had similar problem on Brocade 5300 which was running on 8Gbps for long time but suddenly went down to 4Gbps due to lose of 8Gbps license. I had to install it again .
Contributor
Hi ,
To check installed license: licenseshow .
Please refer the cabling best practices to choose the correct cable and SFP for suitable distance and speed. For example -> PAGE 25.
http://www.brocade.com/downloads/documents/best_practice_guides/Cabling_Best_Practices_GA-BP-036-02.pdf
Frequent Contributor
Hi fbruni,
I have moved your discussion thread to the Data Center SAN Forum as that will be the best place to get your question answered.
Thank you for using Brocade Communities!
Cheers,
Grace Chang
Global Community Manager
