Anonymous
firmware upgrade of switch modules on bladecenter
Hi,
Is upgrading the switch modules on baldecenter is the same as updating a core switch? Is there any specific instructions of updating it compare to core switches? Any inputs is very much appreciated.
Thanks,
kaelo
Anonymous
Re: firmware upgrade of switch modules on bladecenter
HI kaelo
Yes you follow the same procedures as you would do a normal switch , just make sure you follow the correct upgrades if your a few Fabric OS's behind. And you should be fine.
David
