Turn on suggestions
Showing results for
04-20-2016 04:00 AM
HI,
I need to upgrade my firmware of my two brocade 300
I have the 7.0.0c version
I download the last version of the fabric os 7.4.1 in the website of brocade
but when i download with the ftp server he tell me "need files"
I download an other version of the fabric os 7.4.1a in the HP but he needed to migrate on the version 7.2 before
I download the version of the fabric os 7.2.1 in the site of HP
http://h20564.www2.hpe.com/hpsc/swd/public/detail?swItemId=co_159155_1&swEnvOid=54#tab-history
But now he tell me
"The following item(s) need to be addressed before downloading the specified firmware:
Non disruptive firmwaredownload is not supported when firmwaredownload with two versions apart. Please try to use "firmwaredownload" with single mode option enabled.
Firmwaredownload failed."
Please help me
Thanks
04-20-2016 04:14 AM
you have to follow this DOC
from current 7.0.0c to >FOS v7.0.2c/d/e → FOS v7.1.1a/b/c* →FOS v7.2.1a/b/c/d and so on....
otherwise firmwaredownload failed.
04-20-2016 05:49 AM
Thanks for your help
But now the problem where i can download this firmware ?
04-20-2016 05:52 AM
By you OEM/ Reseller in this case HP
04-20-2016 06:05 AM
I buy the brocade with fujitsu
I find the firmware thank you very much
i don't find the 7.0.2 but the 7.0.1 and after 7.1.0a
I can upgrade ?
04-26-2016 05:21 AM - edited 04-26-2016 05:24 AM
Until you go to the steps 7.1.X, 7.2.X, 7.3.X, this is ok. Better is to use recommended reseller versions.
04-26-2016 10:29 AM
Keep in mind that besides the multiple one step upgrades (e.g FOS7.0.0 -> FOS v7.0.2 -> FOS v7.1.1) you could do the following starting from FOS 7.4.0:
Firmware clean install to FOS v7.4.1b from FOS v6.4 or later without retaining any configuration is supported.
But certainly make sure that it is applicable to your environment. It is disruptive.
