Anonymous
firmware not upgrading
Hello All,
I downloaded the firmvare v6.1.2c for my 200E switch.The current version is v6.0.0c.I unziped to a folder v6.1.2c and there are many folders like SWBD21,23,...etc.then I put the folder v6.1.2c in the ftp server say (10.28.25.245).from my IE when try to access the folder by ftp(ftp://10.28.25.245/) I am able to see all the folders like SWBD21,23 etc.
now the problem is when I try to upgrade the firmware through the telnet getting error as below....
SW1:admin> firmwaredownload
Server Name or IP Address: 10.28.25.245
User Name: test
File Name: /v6.1.2c/release.plist
Network Protocol(1-auto-select, 2-FTP, 3-SCP) : 2
Password:
Checking system settings for firmwaredownload...
Protocol selected: FTP
Trying address-->AF_INET IP: 10.28.25.245, flags : 2
The server is inaccessible or firmware path is invalid. Please make sure the server name or IP address, the user/password and the firmware path are valid.
SW1:admin>
Any help?
thanks
Anonymous
Re: firmware not upgrading
Hi,
please check if your ftp structure is like this ftproot/v6.1.2c/....
You wrote--> IE when try to access the folder by ftp(ftp://10.28.25.245/) I am able to see all the folders like SWBD21,23
This looks to me that you have copied the content of the frimwarefolder to the FTP root.
Check if you have a firewall between the switches and the ftp server.
Check your ftpserver logs if you can see the login of the switch.
Regards,
Andreas
Anonymous
Thank you working fine now .The problem was with the ftp file structure.Ableto upgrade.
