Anonymous
fci.device.login.reject :::: reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
we are seeing these messages on our filer
Current FAB OS
version
Kernel:     2.6.14.2
Fabric OS:  v6.3.2a
Made on:   Thu Sep 2 17:35:28 2010
Flash:         Fri Apr 29 00:34:20 2011
BootProm:   1.0.9
Filer 1::::
Thu Oct 13 17:32:49 AST : Event 'fci.device.login.reject' suppressed 4474 times since Thu Oct 13 17:17:40 AST 2011.
Thu Oct 13 17:32:49 AST : The PLOGI transmitted by port 0c was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Thu Oct 13 18:47:56 AST : Event 'fci.device.login.reject' suppressed 4486 times since Thu Oct 13 18:32:52 AST 2011.
Thu Oct 13 18:47:56 AST : The PLOGI transmitted by port 0d was rejected by port_id 0x40ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Thu Oct 13 16:02:22 AST : Event 'fci.device.login.reject' suppressed 4559 times since Thu Oct 13 15:47:22 AST 2011.
Thu Oct 13 16:02:22 AST : The PLOGI transmitted by port 3a was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Thu Oct 13 17:17:40 AST : Event 'fci.device.login.reject' suppressed 4558 times since Thu Oct 13 17:02:36 AST 2011.
Thu Oct 13 17:17:40 AST : The PLOGI transmitted by port 3b was rejected by port_id 0x40ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Filer 2::::
Sat Oct 15 16:38:00 AST : Event 'fci.device.login.reject' suppressed 4559 times since Sat Oct 15 16:23:00 AST 2011.
Sat Oct 15 16:38:00 AST : The PLOGI transmitted by port 3a was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Sat Oct 15 16:53:00 AST : Event 'fci.device.login.reject' suppressed 4439 times since Sat Oct 15 16:38:00 AST 2011.
Sat Oct 15 16:53:00 AST : The PLOGI transmitted by port 3a was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Sat Oct 15 17:38:14 AST : Event 'fci.device.login.reject' suppressed 4552 times since Sat Oct 15 17:23:15 AST 2011.
Sat Oct 15 17:38:14 AST : The PLOGI transmitted by port 0c was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Sat Oct 15 17:53:14 AST : Event 'fci.device.login.reject' suppressed 4559 times since Sat Oct 15 17:38:14 AST 2011.
Sat Oct 15 17:53:14 AST : The PLOGI transmitted by port 0c was rejected by port_id 0x20ac7 with reason code 'Reserved', explanation code 'Service Parm Error - Rec Data Field Size'.
Brocade switch model 300
I dont see any error messages in errhow
::::::same for all 4 switches::::
Ports of Slot 0    0  1  2  3    4  5  6  7    8  9 10 11   12 13 14 15
Speed             8G 4G 4G AN   8G 4G 4G 4G   AN 4G 4G 4G   AN 4G AN AN
Fill Word          0  0  0  0    0  0  0  0    0  0  0  0    0  0  0  0
AL_PA Offset 13   .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Trunk Port        .. ON ON ON   ON ON ON ON   ON ON ON ON   ON ON ON ON
Long Distance     LE .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
VC Link Init      ON .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Locked L_Port     .. .. .. ..   .. ON ON ON   .. ON ON ON   .. ON .. ..
Locked G_Port     .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Disabled E_Port   .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
ISL R_RDY Mode    .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
RSCN Suppressed   .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Persistent Disable.. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
NPIV capability   ON ON ON ON   ON ON ON ON   ON ON ON ON   ON ON ON ON
QOS E_Port        .. AE AE AE   AE AE AE AE   AE AE AE AE   AE AE AE AE
Mirror Port       .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Rate Limit        .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Credit Recovery   ON ON ON ON   ON ON ON ON   ON ON ON ON   ON ON ON ON
Fport Buffers     .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Port Auto Disable .. .. .. ..   .. .. .. ..   .. .. .. ..   .. .. .. ..
Fault Delay        0  0  0  0    0  0  0  0    0  0  0  0    0  0  0  0
diagshow /// porterrshow
bcc-701-38a
Port     BPort    Diag     Active   Speed     FrTX      FrRX      LLI Errs   Loopback
 0/0      23       OK        UP     8Gbps     1330610116 3415799376 413824
 0/1      21       OK        UP     4Gbps     2062129653 203929474 207384
 0/2      19       OK        UP     4Gbps     2346749476 221997632 207373
 0/3      17       OK        DN     8G Auto   --        --        --
 0/4      22       OK        UP     8Gbps     803472785 657606604 342
          frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy
       tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig
  0:    1.3g   3.4g   0      0      0      0      0      0      0    413.8k   0      0      0      0      0
  1:    2.0g 203.9m   0      0      0      0      0      0    203    207.1k   0      2      3      0      0
  2:    2.3g 221.9m   0      0      0      0      0      0    192    207.1k   0      2      3      0      0
  3:    0      0      0      0      0      0      0      0      0      0      0      0      0      0      0
  4:  803.4m 657.6m   0      0      0      0      0      0    342      7      1      3      3      0      0
bcc-701-38b
 0/0      23       OK        UP     8Gbps     1452129814 2773359265 417659
 0/1      21       OK        UP     4Gbps     698433850 77568184  207316
 0/2      19       OK        UP     4Gbps     1944503651 175858262 207398
 0/4      22       OK        UP     8Gbps     8419782   8419792   208
  0:    1.4g   2.7g   0      0      0      0      0      0      4.0k 413.6k   1      1      1      0      0
  1:  698.4m  77.5m   0      0      0      0      0      0    131    207.1k   0      2      3      0      0
  2:    1.9g 175.8m   0      0      0      0      0      0    213    207.1k   0      2      3      0      0
  4:    8.4m   8.4m   0      0      0      0      0      0    207      6      1      3      3      0      0
Ecc2-701-38a
 0/0      23       OK        UP     8Gbps     3415714979 1330528737 0
 0/1      21       OK        UP     4Gbps     4140395863 2662088818 1420783
 0/2      19       OK        UP     4Gbps     3178164943 2227536221 427807
 0/4      22       OK        UP     8Gbps     657584980 803447516 133
  0:    3.4g   1.3g   0      0      0      0      0      0      0      2      0      0      0      0      0
  1:    4.1g   2.6g  11      7      7      0      0      0      1.4m  13      0      3      4      0      0
  2:    3.1g   2.2g  12      7      5      1      0      2    427.7k  16      0      3      4      0      0
  4:  657.5m 803.4m   0      0      0      0      0      0    133      5      1      2      2      0      0
Ecc2-701-38b
 0/0      23       OK        UP     8Gbps     2728227404 1421808515 407764
 0/1      21       OK        UP     4Gbps     2121615437 2939689723 207483
 0/2      19       OK        UP     4Gbps     1712750037 2468680681 207110
 0/4      22       OK        UP     8Gbps     8419460   8419462   262
  0:    2.7g   1.4g   0      0      0      0      0      0      0    407.7k   0      0      0      0      0
  1:    2.1g   2.9g   0      0      0      0      0      0    569    207.3k   0      2      3      0      0
  2:    1.7g   2.4g   0      0      0      0      0      0    189    207.2k   0      2      3      0      0
  4:    8.4m   8.4m   0      0      0      0      0      0    262      5      1      3      3      0      0
Filer 1 HBA:
slot 0: FC Host Adapter 0c (QLogic 2432 rev. 2, N-port, <UP>)
                Firmware rev:      5.4.0
                Host Port Id:      0x20100
                FC Node Name:      5:00a:098000:119608
                FC Port Name:      5:00a:098000:119608
                SFP Vendor:        FINISAR CORP.
                SFP Part Number:   FTLF8524P2BNV
                SFP Serial Number: PJR5HMC
                SFP Capabilities:  1, 2 or 4 Gbit
                Link Data Rate:    4 Gbit
                Switch Port:       bcc-701-38a:1
slot 0: FC Host Adapter 0d (QLogic 2432 rev. 2, N-port, <UP>)
                Firmware rev:      5.4.0
                Host Port Id:      0x40100
                FC Node Name:      5:00a:098100:119608
                FC Port Name:      5:00a:098100:119608
                SFP Serial Number: PJR67DL
                Switch Port:       bcc-701-38b:1
slot 1: FCVI Host Adapter 1a (QLogic 2532(2562) rev. 2, F-port, <UP>)
                Physical link: UP
                FC Node Name:   21:00:00:24:ff:2e:66:76
                Firmware rev:   5.3.2   Serial No:      RFD1110M43059
                Host Port Id:   0x20400
                Cacheline size: 8       FC Packet size: 2048
                SFP Part Number:        FTLF8528P2BCV-QL
                SFP Serial Number:      PK94FZP
                SFP Capabilities:  2, 4 or 8 Gbit
                Link Data Rate: 8 Gbit
                Switch Port:    bcc-701-38a:4
                        I/O base 0x00000000ffffff00, size 0x100
                        memory mapped I/O base 0xde400000, size 0x4000
        slot 1: FCVI Host Adapter 1b (QLogic 2532(2562) rev. 2, F-port, <UP>)
                Physical link: UP
                FC Node Name:   21:00:00:24:ff:2e:66:77
                Host Port Id:   0x40400
                SFP Serial Number:      PK94G0W
                Switch Port:    bcc-701-38b:4
                        memory mapped I/O base 0xde404000, size 0x4000
        slot 3: FC Host Adapter 3a (QLogic 2432 rev. 3, N-port, <UP>)
                Board name:        QLE2464
                Serial Number:     LFD1110L44927
                Firmware rev:      5.4.0
                Host Port Id:      0x20200
                FC Node Name:      2:000:0024ff:619dc4
                FC Port Name:      2:100:0024ff:619dc4
                SFF Vendor:        FINISAR CORP.
                SFF Part Number:   FTLF8524E2KNL
                SFF Serial Number: PK51Z2P
                SFF Capabilities:  1, 2 or 4 Gbit
                Switch Port:       bcc-701-38a:2
slot 3: FC Host Adapter 3b (QLogic 2432 rev. 3, N-port, <UP>)
                Board name:        QLE2464
                Firmware rev:      5.4.0
                Host Port Id:      0x40200
                FC Node Name:      2:000:0024ff:619dc5
                FC Port Name:      2:100:0024ff:619dc5
                SFF Serial Number: PK51Z2H
                Switch Port:       bcc-701-38b:2
Slot 0: 0c connected to bcc-701-38a switch port 0/1
Slot 1: 1a connected to bcc-701-38a switch port 0/4
Slot 3: 3a connected to bcc-701-38a switch port 0/2
Slot 0: 0d connected to
bcc-701-38b switch port 0/1
Slot 1: 1b connected to bcc-701-38b switch port 0/4
Slot 3: 3b connected to bcc-701-38b switch port 0/2
Filer 2 HBA:
same as Filer 1.
does changing cables will fix the LLI Errs /port errors?
does this FabOS has any known issues with  QLogic 2432 rev. 2 Firmware rev 5.4.0
and not with QLogic 2532(2562) rev. 2 Firmware rev 5.3.2?
why we see more errors on a Link Data Rate: 4 Gbit speed ( switch 0/4 slot Link Data Rate: 8 Gbit)?
or anything else?
thanx in advice.
