Anonymous
fabric on model 300
Hi,
i have problem with two switches model 300. I need this switches connect to fabric. Domain IDs are 1 for SW001 and 2 for SW002
My licenses on both swithes:
SW001:admin> licenseshow
Szzyyccbzdb00zzM:
    Trunking license
SzzyyccbzdT04zzI:
    First Ports on Demand license - additional 8 port upgrade license
WB7KNLaaWLFNgN94N4aGZYKFTWMJWREfB7DXA:
    Enhanced Group Management license
gT4XTYGCLKgFrr7PNDXXFNtQRNXrTfgXBARAC:
    8 Gig FC license
SW001:admin> trunkshow
  1: 14-> 14 10:00:00:05:33:68:21:45     deskew 15 MASTER
     15-> 15 10:00:00:05:33:68:21:45     deskew 16
SW001:admin> fabstatsshow
Description                  Count   Port    Timestamp
Domain ID forcibly changed:       0
E_Port offline transitions:       0
Reconfigurations:                 0
Segmentations due to:
                  Loopback:       0
           Incompatibility:       4
                   Overlap:       0
                    Zoning:       0
            E_Port Segment:       0
                 Licensing:      20 <    14  Mon Jul 15 07:05:47 2013
           Disabled E_Port:       0
               Platform DB:       0
       Sec Incompatibility:       0
             Sec Violation:       0
                 ECP Error:       0
             Duplicate WWN:       0
            Eport Isolated:       0
        AD header conflict:       0
  DomainID offset conflict:       0
  McData SafeZone conflict:       0
            VF AD conflict:       0
  MSFR/RD H&T WWN conflict:       0
      ETIZ Incompatibility:       0
     ESC detected conflict:       0
'<'  - Denotes the type of event that occurred last.
SW002:admin> fabricshow
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
  2: fffc02 10:00:00:05:33:68:3a:1b 172.16.176.183  0.0.0.0        >"SW002"
Have I problem with trunking License?
Thank you
R.P
Anonymous
Re: fabric on model 300
Hi Radek,
No, it is not a trunking issue!
Probably you do not have a fabric license, as I see.
Due to missing fabric license switches can not join to any fabric.
Some explanation: the cheapest SAN switches (typícally the 8 port entry level SAN switches) for example HP B type AM866A doe not have fabric license. (The vendors say: it is a "0 e" ports switch, or "this switch best for the single switch fabric").
Do you have any error message?
Best regards,
Lajos
External Moderator
dobos,
You are right about missing Fabric License, however this issue is very strong because in order to add Trunking License, Fabric License is required first.
radek,
try with this Temporarily UTL Fabric License and let me know if work or not.
you can add the license with command "licenseadd"
Full Fabric (E_Port) License
JSHENMtaHLG9DYPZJPAaHFfS3CSP3mgCJAEBZtXACDDaSAAAGG
TechHelp24
Anonymous
Hi,
Firstly thank you for your message. I thought I needed only trunking license. If I add Full Fabric license, must I doing switch restart?
Thank you!
Radek
External Moderator
accord licenseshow output you posted here
-->>My licenses on both swithes:
Szzyyccbzdb00zzM:
    Trunking license
the switch is Trunking licensed, you need just a Fabric License, and not trunking.
--->>>If I add Full Fabric license, must I doing switch restart?
try with "switchdisable" and the "switchenable"
keep in mind, this command is traffic disruptive for short time.
TechHelp24
Anonymous
SW001:
RQe9QcRS9daRfARc:
    Trunking license
RQe9QcRS9dSRjARY:
JMYA9EraT7DSSXXKMfNEgTFHmTHfRAEABJ9DJ:
9HCmXgDNE3GKMBXS7ENBg7CXASFGP7KFBJHMA:
    8 Gig FC license
JSHENMtaHLG9DYPZJPAaHFfS3CSP3mgCJAEBZtXACDDaSAAAGG:
    Fabric license
    Expiry Date 09/14/2013
SW002:
Szzyyccbzdb00zzM:
    Trunking license
SzzyyccbzdT04zzI:
    8 Gig FC license
    Fabric license
External Moderator
now, since you have added a temporarily fabric License you should be able to form a Fabric.
keep in mind you must purchase a license for both switch ASAP, before the license expired.
if you are satisfied, and all you question are answered, please close this thread.
TechHelp24
Anonymous
OK, switch disable and switch enable I'll do on Sunday. Thank you for your help
Anonymous
Hi, commands switchdisable and then switchenable did not help. I still see:
islshow
1: 15-> (incompatible)
on second switch:
fabricshow
1: fffc01 10:00:00:05:33:68:21:45 172.16.176.182     0.0.0.0     SW0001
on second switch:
2: fffc02 10:00:00:05:33:68:3a:1b 172.16.176.183     0.0.0.0     SW0002
Additional Info in Web Tool first switch and 15th port:
(Segmented) (No Fabric License) (Trunk master) (trunkport)
thank you
Radek Poredsky
Anonymous
islshow
on second switch:
fabricshow
on second switch:
thank you
Radek Poredsky
