Anonymous
extended fabric problem between two DCX backbones
Hi There
Do anyone had a problem with a data replication between two DCX 's on a extended fabric
Let me describe my problem : I cannot do any data replication between my two DCX's running over a DWDM on 4GB
But if I try to do the same between two 48000 over the same DWDM it works fine . only difference is that the 48000 is 4GB and the DCX is 8 GB ports
Any suggestion if I want to use the DCX without any hickups
New Contributor
Re: extended fabric problem between two DCX backbones
Your switch ports are set to auto negotiate right? Your not hard setting links at 8Gb on each side of the 4gb dwdm? We have dark fiber between our two DC's with in metro distance and just use the 30km single mode optics. Saves a ton on DWDM costs.
-Will
Anonymous
Did you have compared your portcfg settings between both platforms?
It could also help if you post some informationof the DWDM solution.
Distance and vendor and so on...
Can you please be a bit more specific what your error is between both DCXes?
Did you have a performance issue or latency issue or did no ISL connection will be establish between both directors.
Regards,
Andreas
Anonymous
  1. Check fillwords. On 8G they should normally be arb(ff)
  2. Verify if your DWDM kit supports that in addition to virtual channels.
  3. If not, use IDLE fillword, turn off credit-recovery and VC link init and turn on ISL R_RDY mode.
  4. Ask your DWDM vendor for either a software upgrade to support these functions or, if thats not possible, shop around for new kit.
The ARB(ff) fillword doesn't exist on the 48K since thats 4G. (Only in loop mode you might run into ARB(ff) but that doesn't apply here). The ARB(ff) fillword was introduced on 8G speeds again since it provides a better bitpattern to prevent some electrical issues. Google around, enough docs availble on this topic. You might want to start of here : http://www.hitachi-storage.com/content/fill-words-what-are-those-what-do-they-do-and-why-are-they-needed
Good luck
Erwin
