Occasional Contributor
er_bad_os and Proc_rqrd problem
HI:team
  i have a BR5300,when i use  portstatsshow command,i find that the value of er_bados_os and Proc_rqrd are increased fast.so anyone know what the problem?
stat_wtx            	912015      4-byte words transmitted
stat_wrx            	59094       4-byte words received
stat_ftx            	3723        Frames transmitted
stat_frx            	3077        Frames received
stat_c2_frx         	0           Class 2 frames received
stat_c3_frx         	3077        Class 3 frames received
stat_lc_rx          	0           Link control frames received
stat_mc_rx          	0           Multicast frames received
stat_mc_to          	0           Multicast timeouts
stat_mc_tx          	0           Multicast frames transmitted
tim_rdy_pri         	0           Time R_RDY high priority
tim_txcrd_z         	0           Time TX Credit Zero (2.5Us ticks)
tim_txcrd_z_vc  0- 3:  0           0           0           0
tim_txcrd_z_vc  4- 7:  0           0           0           0
tim_txcrd_z_vc  8-11:  0           0           0           0
tim_txcrd_z_vc 12-15:  0           0           0           0
er_enc_in           	0           Encoding errors inside of frames
er_crc              	0           Frames with CRC errors
er_trunc            	0           Frames shorter than minimum
er_toolong          	0           Frames longer than maximum
er_bad_eof          	0           Frames with bad end-of-frame
er_enc_out          	0           Encoding error outside of frames
er_bad_os           	4064150932  Invalid ordered set
er_rx_c3_timeout    	0           Class 3 receive frames discarded due to timeout
er_tx_c3_timeout    	0           Class 3 transmit frames discarded due to timeout
er_c3_dest_unreach  	0           Class 3 frames discarded due to destination unreachable
er_other_discard    	0           Other discards
er_type1_miss       	0           frames with FTB type 1 miss
er_type2_miss       	0           frames with FTB type 2 miss
er_type6_miss       	0           frames with FTB type 6 miss
er_zone_miss        	0           frames with hard zoning miss
er_lun_zone_miss    	0           frames with LUN zoning miss
er_crc_good_eof     	0           Crc error with good eof
er_inv_arb          	0           Invalid ARB
open                	0           loop_open
transfer            	0           loop_transfer
opened              	0           FL_Port opened
starve_stop         	0           tenancies stopped due to starvation
fl_tenancy          	0           number of times FL has the tenancy
nl_tenancy          	0           number of times NL has the tenancy
zero_tenancy        	0           zero tenancy
portstats64show 40
stat64_wtx  	0           top_int : 4-byte words transmitted
            	912015      bottom_int : 4-byte words transmitted
stat64_wrx  	0           top_int : 4-byte words received
            	59094       bottom_int : 4-byte words received
stat64_ftx  	0           top_int : Frames transmitted
            	3723        bottom_int : Frames transmitted
stat64_frx  	0           top_int : Frames received
            	3077        bottom_int : Frames received
stat64_c2_frx	0           top_int : Class 2 frames received
             	0           bottom_int : Class 2 frames received
stat64_c3_frx	0           top_int : Class 3 frames received
             	3077        bottom_int : Class 3 frames received
stat64_lc_rx	0           top_int : Link control frames received
            	0           bottom_int : Link control frames received
stat64_mc_rx	0           top_int : Multicast frames received
            	0           bottom_int : Multicast frames received
stat64_mc_to	0           top_int : Multicast timeouts
            	0           bottom_int : Multicast timeouts
stat64_mc_tx	0           top_int : Multicast frames transmitted
            	0           bottom_int : Multicast frames transmitted
tim64_rdy_pri	0           top_int : Time R_RDY high priority
            	0           bottom_int : Time R_RDY high priority
tim64_txcrd_z	0           top_int : Time BB_credit zero
            	0           bottom_int : Time BB_credit zero
er64_enc_in 	0           top_int : Encoding errors inside of frames
            	0           bottom_int : Encoding errors inside of frames
er64_crc    	0           top_int : Frames with CRC errors
            	0           bottom_int : Frames with CRC errors
er64_trunc  	0           top_int : Frames shorter than minimum
            	0           bottom_int : Frames shorter than minimum
er64_toolong	0           top_int : Frames longer than maximum
            	0           bottom_int : Frames longer than maximum
er64_bad_eof	0           top_int : Frames with bad end-of-frame
            	0           bottom_int : Frames with bad end-of-frame
er64_enc_out	0           top_int : Encoding error outside of frames
            	0           bottom_int : Encoding error outside of frames
er64_disc_c3	0           top_int : Class 3 frames discarded
            	0           bottom_int : Class 3 frames discarded
er64_pcs_blk	0           top_int : PCS block errors
            	0           bottom_int : PCS block errors
stat64_rateTxFrame	3           Tx frame rate (fr/sec)
stat64_rateRxFrame	2           Rx frame rate (fr/sec)
stat64_rateTxPeakFrame	33          Tx peak frame rate (fr/sec)
stat64_rateRxPeakFrame	59          Rx peak frame rate (fr/sec)
stat64_rateTxWord	858         Tx Word rate (words/sec)
stat64_rateRxWord	26          Rx Word rate (words/sec)
stat64_rateTxPeakWord	4766        Tx peak Word rate (words/sec)
stat64_rateRxPeakWord	3566        Rx peak Word rate (words/sec)
stat64_PRJTFrames	0           top_int : 4-byte words transmitted
                 	0           bottom_int : 4-byte words transmitted
stat64_PBSYFrames	0           top_int : 4-byte words transmitted
stat64_inputBuffersFull	0           top_int : 4-byte words transmitted
stat64_rxClass1Frames	0           top_int : 4-byte words transmitted
stat64_aveTxFrameSize	286         Average Tx Frame size
stat64_aveRxFrameSize	13          Average Rx Frame size
portrouteshow 40
port address ID: 0x0b2800
external unicast routing table:
   0: Embedded
 255: Embedded
internal unicast routing table:
portcamshow 40
Port  SID used  DID used  SID entries  DID entries
40     0         0         000000       000000
SID free, DID free: (15278, 15278)
ptbufshow, ptcreditshow, ptdatashow, ptstatsshow 40
S:
S:VF Enable:		1
S:Core hold time:		0
C:
C:------ blade port 15: F_port ------------------------------------------
C:0x860f2400: bbc_trc                 0007 0000 0000 0000 0000 0000 0000 0000
C:0x860f2420: bbc_trc                 0000 0000 0000 0000 0000 0000 0000 0000 0000
C:0x860f2480: bbc_rqc                 0000 0000 0000 0000 0000 0000 0000 0000
C:0x860f24a0: bbc_rqc                 0000 0000 0000 0000 0000 0000 0000 0000 0000
C:0x860f2500: bbc_mbc                 0000 0000 0000 0000 0000 0000 0000 0000
C:0x860f2520: bbc_mbc                 0000 0000 0000 0000 0000 0000 0000 0000 0000
C:0x860f2580: bbc_rqc_inc             00000000	0x860f2584: bbc_threshold           00000010
C:0x860f2588: bbc_fbpc                00000000	0x860f258c: bbc_csc                 00000000
C:0x860f2590: bbc_tcc_inc             00000000
E:Connection type: FE
E:Port type: F_port
E:Trunk port: No
E:Configured Speed: AUTO_SPEED_NEGO
E:Max Capable Speed: 8G
E:Current SNSM Speed: 8G
E:Hardware TX Speed: 8G (0x2259c33a)
E:Interrupts: 	0           Link_failure:	0
Loss_of_sync:	0           Loss_of_sig:	0
E:Lli:     	0           Invalid_word:	0
E:trapped_frm:	162         fwd_status_ok:	162
E:fwd_timeout:	0           fwd_tx_unavail:	0
E:fwd_unroutable:	0           fwd_zone_out:	0
E:fwd_other_err:	0           frm_err_discard:	0
E:Fltr listA:	0           Fltr listB: 	0
E:Zone trap fwd:	0           Zone trap disc:   	0
E:shim_csum:	0           RTE_perr:    	0
E:Invalid_crc:	0           Delim_err:   	0
E:Inv alpa disc:	0           Protocol_err:	0
E:Lr_in:      	0           Lr_out:     	0
E:Ols_in:     	0           Ols_out:    	0
S:
S:C2 Global Variable:
S:---------------------------------------------------------------------------
S:trace_stop:		0
S:
S:C2 Phy Data Pointers: c2_phyp = 0x6fbe6800
S:tnodep			0x6fbe23c0	pt			0x4302800f
S:proto_phyp		0x6fbd72e0	phy_cfg			0x6fbde400
S:c2_chp			0x6fb40000	c2_lgcp		0x715b1000
S:c2_phy_regp		0x860f0000	proc_dir		0x6fbe4d20
S:magic_id        	0x456789ab	num_port_timer		14
S:prev_if_id      	0x4302000f	shared_if_id    	0x0
S:ftx			3723    	tov			1000
S:initialized		1       	port_idx		15
S:ui_idx			40      	slot_no			0
S:blade_idx		15      	sw_usr_ports		400
S:unused			0       	intr_debounced		0
S:num_fault1_rx_disc	0       	num_fault2_rx_disc	0
S:p_lli_cause0		0       	p_sig_regained		0
S:p_sync_regained		0       	enc_out			0x0
S:cached_fps_status	128     	cached_sts_status	0
S:cached_er_crc_good_eof	0       	cached_er_enc_out	0
S:cached_er_bad_os	0       	cached_er_too_long	0
S:cached_er_trunc	0       	cached_tot_er_crc_good_eof	0
S:num_pt_excess_intr	0       	num_no_fid		0
S:num_fault1_cnt		0       	num_fault2_cnt		0
S:num_fault_lip		0       	num_fault_lli		0
S:num_fault_rx_fifo	0       	num_fault_hss		0
S:num_fault_bwait		0       	num_fault_tx_to		0
S:lli_intr_prim		0       	S:num_sw_link_to		0       	be_link_err_mon_count		0
S:sn_speed		0       	reason_code		0
S:num_efifo_debounce_cnt		0       	num_efifo_overflow_cnt		0
S:num_be_lr		0       	num_be_lto		0
S:check_lto		0       	credit_loaded		7
S:num_credit_overrun		0       	phy_stats_clear_ts		1386649995
S:err_other_disc_loop_init		0       	err_other_disc_loop_exit		0
S:err_other_disc_ignore		0       	phy_port_status		2
S:
S:	c2_trunk
S:========================================
S:mark_ts         	0x0       	deskew          	0x0
S:master_phyp     	0x0
S:
S:adelay[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:adelay[04]: 0x00000000 0x00000000 0x00000000 0x00000000
S:
S:	c2_buf
S:tx_csc			0       	rx_csc			0
S:ld_vc_credits		0       	tx_flag         	0x0
S:alloc_buffers		8       	req_buffers		8
S:est_buffers		8       	ld_use_est		0
S:bb_sc_n			0       	rx_bb_sc_n		0
S:data_cr			5       	nondata_cr		6
S:ld_nondata_cr		6       	tnodep          	0x6fbe2300
S:tx_credits[0]	0    0    0    0    0    0    0    0
S:tx_credits[8]	0    0    0    0    0    0    0    0
S:tx_credits[16]	0    0    0    0    0    0    0    0
S:rx_credits[0]	0    0    0    0    0    0    0    0
S:rx_credits[8]	0    0    0    0    0    0    0    0
S:rx_credits[16]	0    0    0    0    0    0    0    0
S:tx_mbc[0]	0    0    0    0    0    0    0    0
S:tx_mbc[8]	0    0    0    0    0    0    0    0
S:tx_mbc[16]	0    0    0    0    0    0    0    0
S:rx_mbc[0]	0    0    0    0    0    0    0    0
S:rx_mbc[8]	0    0    0    0    0    0    0    0
S:rx_mbc[16]	0    0    0    0    8    0    8    0
S:
S:C2 Chip Variables: c2_phyp->c2_chp = 0x6fb40000
S:magic_id        	0x3456789a	init_state      	0x8
S:reset_reg_mem   	0x1
S:ch_int_en_bm    	0x0       	intr_cause      	0x0
S:ch              	0x43010080	ch_cfg          	0x6f823000
S:raslog_hndl.hndl	0x0       	obj_halted      	0x0
S:c2_chip_regp    	0x85400000	num_chip_timer  	0x6
S:hi_task_bm      	0x0       	lo_task_bm      	0x0
S:c2_deferq.q_head	0x0       	c2_deferq.q_tail	0x0
S:c2_tmrq.q_head  	0x0       	c2_tmrq.q_tail  	0x0
S:fltr_bm         	0x0       	slot_no			0
S:chip_inst		0       	chip_idx		0
S:pll_initialized		1       	pll_serdes_initialized	1
S:init_tries		0       	init_ptEnableBM 	0x6f9a0880
S:tick_polling    	0x6fbb0d60	sec_polling     	0x6fbb0da0
S:version			0       	bb_fid			129
S:c2_phyp[00]: 0x76c88800 0x6fbb3800 0x6fbb3000 0x6fbba800
S:c2_phyp[04]: 0x6fbba000 0x6fbbe800 0x6fbbe000 0x6fbc8800
S:c2_phyp[08]: 0x6fbc8000 0x6fbce800 0x6fbce000 0x6fbd5800
S:c2_phyp[12]: 0x6fbd5000 0x6fbdd800 0x6fbdd000 0x6fbe6800
S:c2_phyp[16]: 0x6fbe6000 0x6fbee800 0x6fbee000 0x6fbf5800
S:c2_phyp[20]: 0x6fbf5000 0x6fbfc800 0x6fbfc000 0x6f41c800
S:c2_phyp[24]: 0x6f41c000 0x6f423800 0x6f423000 0x6f42a800
S:c2_phyp[28]: 0x6f42a000 0x6f431800 0x6f431000 0x6f438800
S:c2_lgcp[00]: 0x71555000 0x715b4000 0x71598000 0x715b6000
S:c2_lgcp[04]: 0x71559000 0x71558000 0x715b7000 0x7e7f5000
S:c2_lgcp[08]: 0x71550000 0x715a8000 0x7159e000 0x71546000
S:c2_lgcp[12]: 0x715b2000 0x71599000 0x71554000 0x715b1000
S:c2_lgcp[16]: 0x7155b000 0x715ab000 0x71552000 0x7159d000
S:c2_lgcp[20]: 0x72249000 0x722be000 0x7154a000 0x715a2000
S:c2_lgcp[24]: 0x72246000 0x7c43c000 0x7221b000 0x73291000
S:c2_lgcp[28]: 0x71534000 0x71535000 0x71536000 0x71537000
S:chip_timers[00]: 0x6fbb0f20 0x6fbb0ee0 0x6fbb0ea0 0x6fbb0e60
S:chip_timers[04]: 0x6fbb0e20 0x6fbb0de0
S:
S:C2 Logical Port Variables
S:c2_lgc_regp		0x860f0000
S:c2_phyp:
S:	0x6fbe6800	0x0       	0x0       	0x0
S:	0x0       	0x0       	0x0       	0x0
S:master_phyp		0x6fbe6800	if_id			0x4302000f
S:min_phyp		0x0       	max_phyp		0x0
S:num_phy_ports		1       	lgc_num			15
S:num_iu_to		0       	sw_txq_bm			0
S:port_fid		128     	unused			0
S:port_group		2       	S:lgc_stats_clear_ts			1386649995
S:
S:Proto Phy Variables:
S:magic_id		0x23456789	asic_phyp		0x6fbe6800
S:port_id			0x4302800f	phy_cfg			0x6fbde400
S:upsm_hdl		0x6fbe18c0	physm_hdl		0x6fbe1b40
S:ov_snsm_hdl		0x6fbe1c40	sw_snsm_hdl		0x6fbe1bc0
S:lpsm_hdl		0x6fbe19c0	ov_lksm_hdl		0x6fbe1ac0
S:sw_lksm_hdl		0x6fbe1a40	trksm_hdl		0x6fbe1940
S:lr_flag		0x0
S:
S:UPSM      UP22: UPST_G_PORT         	--> UP23: UPST_F_PORT
S:SNSM(OV)  SN02: OV_SNST_HW_NEG   	--> SN04: OV_SNST_NEGOTIATED
S:SNSM(SW)  SW00: SW_SNST_STAGE_WS 	--> SW00: SW_SNST_STAGE_WS
S:PHYSM     PP04: PHYST_NO_SYNC    	--> PP05: PHYST_IN_SYNC
S:LKSM(OV)  LK02: OV_LKST_HW_INIT     	--> LK04: OV_LKST_ACTIVE
S:LKSM(SW)  SW13: INACTIVE        	--> SW13: INACTIVE
S:TRKSM     TRK0: TRKST_INIT       	--> TRK0: TRKST_INIT
S:LPSM      LP01: LPST_NORMAL_INITIALIZE	--> LP00: LPST_STOP_LOOP
S:
S:lpsm variables:
S:fantx_devmap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:online_loginmap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:cumulative_lifamap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:rcvd_lifamap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:rcvd_lisamap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:rcvd_lirpmap[00]: 0x00000000 0x00000000 0x00000000 0x00000000
S:rcvd_lirpmap[04]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[08]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[12]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[16]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[20]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[24]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:rcvd_lirpmap[28]: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
S:proto_phyp		0x6fbd72e0	lpsm_hdl		0x6fbe19c0
S:event			0x4040001 	lpsm_iu			0x0
S:wait_on_upsm_start	0x0       	lip_in_use		0xbc15f7f7
S:hw_lpsm_state		0x0       	hw_lixx_term_rsn	0x0
S:frm_rcvd		0x0       	num_of_nl		0x0
S:hw_lixx_tries		0x0       	sw_lixx_tries		0x0
S:l_bit_set		0x1       	hw_fan_success		0x0
S:tx_fan_reqd		0x0       	sw_lixx_mode		0x1
S:tx_cls			0x0       	lirp_lilp_done		0x0
S:
S:physm variables:
S:proto_phyp		0x6fbd72e0	physm_hdl		0x6fbe1b40
S:force_offline		0       	copper			0
S:fault_reason		0: UNKNOWN
S:
S:snsm variables:
S:speed			0x5       	proto_phyp		0x6fbd72e0
S:hw_sn_tries_left	0x64      	sw_sn_tries_left	0x5
S:curr_txsp_count		0x0
S:tx_max			0x0       	curr_tx_indx		0x0
S:curr_tx			0x0       	curr_rxsp_count		0x0
S:rx_max			0x0       	curr_rx_indx		0x0
S:curr_rx			0x0       	rx_mem			0x0
S:rxsp_rec_count		0x0
S:nc_start		0x0       	tx_start		0x0
S:sync_start		0x0       	sync_present		0x0
S:diag_auto		0x0       	diag_speed		0xff
S:
S:lksm variables:
S:proto_phyp		0x6fbd72e0	ov_lksm_hdl		0x6fbe1ac0
S:sw_lksm_hdl		0x6fbe1a40	num_lf1			0
S:hw_link_tries_left	0x4       	sw_link_tries_left	0x5
S:buf_ptype		0x0       	stored_entry_state	0x6
S:handshake_owner		0x0       	mark_unsent		0x0
S:busybuf_stuck		0x0       	lr_wait			0x0
S:
S:trksm variables:
S:Not a trunk port
S:
S:upsm variables:
S:proto_phyp		0x6fbd72e0	upsm_hdl		0x6fbe18c0
S:bb_credits		7       	port_beacon		0
S:port_diag_flag		0       	force_offline		0
S:port_fault_rsn		0: PORT_NO_FAULT
S:retry_init_rsn		0: UNKNOWN
S:linit_reason		0       	linit_result		0
S:ie_fctl_mode		0
S:retry_sn_fail_init	0       	retry_link_fail_init	0
S:excess_lr_count	0
S:
S:c2_ch_cfg
S:c2_desc_ring_size	160      330      160      160      160      160
S:thresh_def		0        0        16       1
S:intr_tries		500     	cmem_pattern		-559038737
S:cmem_pattern_upwd	2       	cmem_init_time		7
S:cmem_init_tries		5
S:ctrl_par_thresh		2       	data_par_thresh		4
S:cam_par_thresh		4       	buf_loss_thresh		12
S:crit_par_thresh		2       	non_crit_par_thresh	6
S:pci_abort_thresh	10      	pci_err_thresh		5
S:excess_chintr_thresh	8       	sw_err_thresh		20
S:err_sample_period	300     	intr_sleep		20000
S:frame_timeout	1000    	proxy_dev		4096
S:vf_route	12288   	qos		512
S:stats	1536    	f_redirect		512
S:rsp_trap	512     	lun_zoning		3932
S:area_mode	0       	ftb_max_loop[0]		0
S:ftb_max_loop[1]	6       	ftb_max_loop[2]		9
S:ftb_max_loop[3]	10      	ftb_max_loop[4]		10
S:ftb_max_loop[5]	5       	ftb_max_loop[6]		6
S:ftb_seg_size[0]	0       	ftb_seg_size[1]		8192
S:ftb_seg_size[2]	16384   	ftb_seg_size[3]		8192
S:ftb_seg_size[4]	8192    	ftb_seg_size[5]		16384
S:ftb_seg_size[6]	8192    	ftb_seg_base[0]		0
S:ftb_seg_base[1]	32768   	ftb_seg_base[2]		0
S:ftb_seg_base[3]	40960   	ftb_seg_base[4]		49152
S:ftb_seg_base[5]	16384   	ftb_seg_base[6]		57344
asic_err_monitor_period1		300
asic_err_monitor_period2		86400
zone_chk_to_poll_period	10
zone_chk_class2_reject_tov		500
S:stuck_vc_detect_tov	2
S:
S:c2_phy_cfg
S:pt			0x4302800f	fab_ptr			0x78400000
S:fabattr			0x784000d4	fab_iop			0x78400050
S:cfgbm			0x6fbe1cc4	port_ctrl		0x6fbde418
S:pcap.pcap_bm		0x8f21555f	S:pcap.pcap2_bm		0x20289
S:pcap.pcap3_bm		0x0       	ui_idx			40
S:slot_no			0       	is_icl			0
S:sw_usr_ports		400
S:neg_speed		5 3 1 0 0 0
S:my_domain		0xb       	port_mode		0x0
S:hw_sn_maxtries		0x64      	sw_sn_maxtries		0x5
S:hw_link_maxtries	0x5       	sw_link_maxtries	0x5
S:rx_cyc_tov		0x14      	rttov			0x12c
S:bufrdy_tov		0x12c     	busybuf_tov		0x11e
S:mark_tov		0x12c     	lksm_tov		0xbb8
S:buf_dealloc_wait	0x4       	hw_wd_tov		0xbb8
S:syswait_tx_12_lips	0x1       	lip_rx_tov		0x37
S:al_time_tov		0xf       	lp_tov			0x7d0
S:hw_lixx_tov		0x3e80    	hw_fan_tx_tov		0x1f4
S:hw_lixx_tries		4       	sw_lixx_tries		2
S:intr_tries_port		500     	intr_mod_debounce	250
S:intr_lsr_flt_debounce	500     	intr_efifo_debounce	10
S:port_no_fid		3       	excess_ptintr_thresh	8
S:port_fault1_thresh	100     	port_fault1_spur_thresh	250
S:port_fault1_disc_thresh	500     	port_fault1_disc_spur_thresh	1000
S:port_fault2_thresh	5       	losync_tov		100
S:port_sw_link_to		15      	en_8g_scramble		1
S:chip_version		0       	frc_hw_sn_mode		0x1
S:enc_poll_thresh		25      	fc_al_reset_tov		20
S:port_paired_prop		4       	port_num		-1
S:port_be_lto_threshold		100     	port_be_lr_threshold		2
S:port_credit_overrun_thresh		10
S:
S:	fab_iop
S:fab_iop->interop_mode	0x0       	fab_iop->lab_mode	0x0
S:fab_iop->fl_bbc		0x0       	fab_iop->fl_fan		0x0
S:fab_iop->fl_cls		0x4       	fab_iop->fl_rscn	0x0
S:fab_iop->domain_id_offset	0x60      	fab_iop->mcdt_fabric_mode	0x0
S:fab_iop->mcdt_default_zone		0x0       	fab_iop->mcdt_safe_zone		0x0
S:
S:	port_ctrl
S:port_ctrl.port_type	1       	port_ctrl.port_grp	2
S:port_ctrl.port_number	40      	port_ctrl.vc_mode	1
S:
S:	port_ctrl.lcap
S:has_serdes		0       	has_media		1
S:topology		0       	skip_nego		0
S:skip_pnego		0       	skip_init_event		0
S:en_shim			0       	speed_neg		1
S:loop_back		0       	num_speeds		4
S:
S:	port_ctrl.speed_list array
S:speed_list[0].auto_neg  1	speed_list[0].lnk_speed  0x00000005
S:speed_list[1].auto_neg  1	speed_list[1].lnk_speed  0x00000003
S:speed_list[2].auto_neg  1	speed_list[2].lnk_speed  0x00000001
S:speed_list[3].auto_neg  0	speed_list[3].lnk_speed  0x00000000
S:speed_list[4].auto_neg  0	speed_list[4].lnk_speed  0x00000002
S:speed_list[5].auto_neg  0	speed_list[5].lnk_speed  0x00000001
S:
S:	port_ctrl.cm
S:port_ctrl.cm.num_vcs		8
S:port_ctrl.cm.min_bufs		8
S:port_ctrl.cm.cr_shar_bufs	0
S:port_ctrl.vc_alloc		2 0 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0
S:port_ctrl.norm_vc_alloc		4 0 5 5 5 5 1 1 0 0 0 0 0 0 0 0 0
S:
S:	port_ctrl.serdes_set
S:serdes_type		0x4
S:serdes_data_t.ibm_hss_serdes.tx_drive_power		0x0
S:serdes_data_t.ibm_hss_serdes.pre_emphasis_b_sign	0x0
S:serdes_data_t.ibm_hss_serdes.pre_emphasis_b		0x0
S:serdes_data_t.ibm_hss_serdes.pre_emphasis_a		0x0
S:serdes_data_t.ibm_hss_serdes.rxeq			0x0
S:
S:	cfgbm
S:old_distance		0x0       	gport_lockdown		0x0
S:tport			0x1       	speed			0x0
S:disable_eport		0x0       	fcacc			0x0
S:lport_lockdown		0x0       	priv_lport_lockdown	0x0
S:vcxlt_linit		0x0       	delay_flogi		0x0
S:isl_interop		0x0       	distance		0x0
S:BufStarvFlag		0x0       	credit_sharing		0x0
S:lport_halfduplex	0x0       	lport_fairness		0x0
S:soft_neg		0x0       	asn_frc_hwretry		0x0
S:cr_recov		0x0       	fport_buffers		0x0
S:export		0x0       	export_mode		0x0
S:csctl_en		0x0       	mirror_port		0x0
S:fault_delay		0
S:port_persistently_disabled (permanently) 0 (0)
S:
S:	cfg property
S:priv_pcfg_bm		0x00000000	lgcl_pcfg_bm		0x6fbe1d04
S:fport_buffer		0x00000000
S:
filterportshow 40
		FILTER DATA
Shadow settings:
   Filter Enable: 0x000004a0
   Redir RAM[0]: 0x00000000
   Redir RAM[1]: 0x00000000
   Redir RAM[2]: 0x00000000
   Redir RAM[3]: 0x00000000
   Redir RAM[4]: 0x00000000
   Redir RAM[5]: 0x00000000
   Redir RAM[6]: 0x00000000
   Redir RAM[7]: 0x00000000
   Redir RAM[8]: 0x00000000
   Redir RAM[9]: 0x00000000
   Redir RAM[10]: 0x00000000
   Redir RAM[11]: 0x00000000
   Redir RAM[12]: 0x00000000
   Redir RAM[13]: 0x00000000
   Redir RAM[14]: 0x00000000
   Redir RAM[15]: 0x00000000
   Redir RAM[16]: 0x00000000
   Redir RAM[17]: 0x00000000
   Redir RAM[18]: 0x00000000
   Redir RAM[19]: 0x00000000
   Bypass: 0x00000000
Shadowed filters:
Filter 0: Not Installed (MIRROR1)(NO-OP)
	c2_fldenable[0] = 0x00000000 0x00000000
	c2_fldnegate[0] = 0x00003fff,c2_fltr_config[0] = 0x00000007
Filter 1: Not Installed (MIRROR2)(NO-OP)
	c2_fldenable[1] = 0x00000000 0x00000000
	c2_fldnegate[1] = 0x00003fff,c2_fltr_config[1] = 0x00000007
Filter 2: Not Installed (MIRROR3)(NO-OP)
	c2_fldenable[2] = 0x00000000 0x00000000
	c2_fldnegate[2] = 0x00003fff,c2_fltr_config[2] = 0x00000007
Filter 3: Not Installed (MIRROR4)(NO-OP)
	c2_fldenable[3] = 0x00000000 0x00000000
	c2_fldnegate[3] = 0x00003fff,c2_fltr_config[3] = 0x00000007
Filter 4: Not Installed (STUCK_VC_DETECT)(NO-OP)
	c2_fldenable[4] = 0x00000000 0x00000000
	c2_fldnegate[4] = 0x00003fff,c2_fltr_config[4] = 0x00000007
Filter 5: Installed (ZONING TRAP)(LISTA)
	c2_fldenable[5] = 0x00000000 0x06007c10
	c2_fldnegate[5] = 0xffffd9ff,c2_fltr_config[5] = 0x000000e0
Filter 6: Not Installed (FCR_EXPORT_DC)(NO-OP)
	c2_fldenable[6] = 0x00000000 0x00000000
	c2_fldnegate[6] = 0x00003fff,c2_fltr_config[6] = 0x00000007
Filter 7: Installed (TIN TRAP)(LISTA)
	c2_fldenable[7] = 0x00000000 0x00200184
	c2_fldnegate[7] = 0xffffecff,c2_fltr_config[7] = 0x00000168
Filter 8: Not Installed (FICON CUP)(NO-OP)
	c2_fldenable[8] = 0x00000000 0x00000000
	c2_fldnegate[8] = 0x00003fff,c2_fltr_config[8] = 0x00000007
Filter 9: Not Installed (FICON CUP DST)(NO-OP)
	c2_fldenable[9] = 0x00000000 0x00000000
	c2_fldnegate[9] = 0x00003fff,c2_fltr_config[9] = 0x00000007
Filter 10: Installed (WELL KNOWN ADDR)(FORWARD)
	c2_fldenable[10] = 0x00000001 0x00000000
	c2_fldnegate[10] = 0xfffffffe,c2_fltr_config[10] = 0x0000002c
Filter 11: Not Installed (UNUSED)(NO-OP)
	c2_fldenable[11] = 0x00000000 0x00000000
	c2_fldnegate[11] = 0x00003fff,c2_fltr_config[11] = 0x00000007
Filter 12: Not Installed (PERF1)(LISTA)
	c2_fldenable[12] = 0x00000000 0x00000000
	c2_fldnegate[12] = 0x00000000,c2_fltr_config[12] = 0x00000000
Filter 13: Not Installed (PERF2)(LISTA)
	c2_fldenable[13] = 0x00000000 0x00000000
	c2_fldnegate[13] = 0x00000000,c2_fltr_config[13] = 0x00000000
Filter 14: Not Installed (PERF3)(LISTA)
	c2_fldenable[14] = 0x00000000 0x00000000
	c2_fldnegate[14] = 0x00000000,c2_fltr_config[14] = 0x00000000
Filter 15: Not Installed (PERF4)(LISTA)
	c2_fldenable[15] = 0x00000000 0x00000000
	c2_fldnegate[15] = 0x00000000,c2_fltr_config[15] = 0x00000000
Filter 16: Not Installed (PERF5)(LISTA)
	c2_fldenable[16] = 0x00000000 0x00000000
	c2_fldnegate[16] = 0x00000000,c2_fltr_config[16] = 0x00000000
Filter 17: Not Installed (PERF6)(LISTA)
	c2_fldenable[17] = 0x00000000 0x00000000
	c2_fldnegate[17] = 0x00000000,c2_fltr_config[17] = 0x00000000
Filter 18: Not Installed (PERF7)(LISTA)
	c2_fldenable[18] = 0x00000000 0x00000000
	c2_fldnegate[18] = 0x00000000,c2_fltr_config[18] = 0x00000000
Filter 19: Not Installed (PERF8)(LISTA)
	c2_fldenable[19] = 0x00000000 0x00000000
	c2_fldnegate[19] = 0x00000000,c2_fltr_config[19] = 0x00000000
Filter dirty indicator: 0x00000000
Performance filters: 0
Port Mirror filters: 0 (0x0)
		FIELD DATA
Shadowed fields:
fldoffset[0] = 0x05,fldmask[0] = 0x00,fldvalue_dyna[0]:0xff 0x00 0x00 0x00
fldcontrol[0].inuse = 0x1000000  fldcontrol[0].refcnt = 0x01 0x00 0x00 0x00
fldoffset[1] = 0x00,fldmask[1] = 0x00,fldvalue_dyna[1]:0x00 0x00 0x00 0x00
fldcontrol[1].inuse = 0x0  fldcontrol[1].refcnt = 0x00 0x00 0x00 0x00
fldoffset[2] = 0x00,fldmask[2] = 0x00,fldvalue_dyna[2]:0x00 0x00 0x00 0x00
fldcontrol[2].inuse = 0x0  fldcontrol[2].refcnt = 0x00 0x00 0x00 0x00
fldoffset[3] = 0x00,fldmask[3] = 0x00,fldvalue_dyna[3]:0x00 0x00 0x00 0x00
fldcontrol[3].inuse = 0x0  fldcontrol[3].refcnt = 0x00 0x00 0x00 0x00
fldoffset[4] = 0x00,fldmask[4] = 0x00,fldvalue_dyna[4]:0x00 0x00 0x00 0x00
fldcontrol[4].inuse = 0x0  fldcontrol[4].refcnt = 0x00 0x00 0x00 0x00
fldoffset[5] = 0x00,fldmask[5] = 0x00,fldvalue_dyna[5]:0x00 0x00 0x00 0x00
fldcontrol[5].inuse = 0x0  fldcontrol[5].refcnt = 0x00 0x00 0x00 0x00
fldoffset[6] = 0x00,fldmask[6] = 0x00,fldvalue_dyna[6]:0x00 0x00 0x00 0x00
fldcontrol[6].inuse = 0x0  fldcontrol[6].refcnt = 0x00 0x00 0x00 0x00
fldoffset[7] = 0x00,fldmask[7] = 0x00,fldvalue_dyna[7]:0x00 0x00 0x00 0x00
fldcontrol[7].inuse = 0x0  fldcontrol[7].refcnt = 0x00 0x00 0x00 0x00
Field dirty indicator: 0x00000000
FDB reference count fdb: 0 [1 0 0 0 ]
FDB reference count fdb: 1 [0 0 0 0 ]
FDB reference count fdb: 2 [0 0 0 0 ]
FDB reference count fdb: 3 [0 0 0 0 ]
FDB reference count fdb: 4 [0 0 0 0 ]
FDB reference count fdb: 5 [0 0 0 0 ]
FDB reference count fdb: 6 [0 0 0 0 ]
FDB reference count fdb: 7 [0 0 0 0 ]
		ACL DATA
Logical port 15: Hard Zoning disabled, Soft Zoning enabled
Zone type: WWN Zoning
Frames with hard zone miss: 0
*** Please use filterportshow on user port 47 to display ACL hash tables in this chip.
*** We show this data only for the first physical port which is an external port.
portFcPortCmdShow --slot 0 41 3
doing portFcPortCmdShow: arg1 = 3, arg2 = -2
portshow 41
portDisableReason: None
portCFlags: 0x1
portFlags: 0x20b03	 PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP ACCEPT FLOGI
LocalSwcFlags: 0x0
portType:  18.0
POD Port: Port is licensed
portState: 1	Online
Protocol: FC
portPhys:  6	In_Sync  	portScn:   32	F_Port
port generation number:    0
state transition count:    2
portId:    0b2900
portIfId:    4302000d
portWwn:   20:29:00:27:f8:0b:e5:7b
portWwn of device(s) connected:
	50:01:43:80:11:39:9a:68
Distance:  normal
portSpeed: N8Gbps
Credit Recovery: Inactive
Aoq: Inactive
FAA: Inactive
F_Trunk: Inactive
LE domain: 0
FC Fastwrite: OFF
Interrupts:        0          Link_failure: 0          Frjt:         0
Unknown:           0          Loss_of_sync: 0          Fbsy:         0
Lli:               0          Loss_of_sig:  0
Proc_rqrd:         161        Protocol_err: 0
Timed_out:         0          Invalid_word: 0
Rx_flushed:        0          Invalid_crc:  0
Tx_unavail:        0          Delim_err:    0
Free_buffer:       0          Address_err:  0
Overrun:           0          Lr_in:        0
Suspended:         0          Lr_out:       0
Parity_err:        0          Ols_in:       0
2_parity_err:      0          Ols_out:      0
CMI_bus_err:       0
portloginshow 41
Type  PID     World Wide Name        credit df_sz cos
  fe  0b2900 50:01:43:80:11:39:9a:68     7  2048   8  scr=0x3
  ff  0b2900  50:01:43:80:11:39:9a:68     0     0   8  d_id=FFFFFC
portregshow 41
GE2 Serdes
0x85e12030: EPB_TXFDR_CTL0_ADDR     0000003b	0x85e12030: EPB_TXFDR_CTL1_ADDR     00000000
0x85e12030: EPB_TXFDR_CTL2_ADDR     00000039	0x85e12030: EPB_TXFDR_CTL3_ADDR     000000c4
0x85e12030: EPB_SMCTL_DFELTH_ADDR   00000008	0x85e12030: EPB_SMCTL_TLTH_ADDR     0000000c
0x85e12030: EPB_SMCTL_ZCNT_ADDR     00000012	0x85e12030: EPB_SMCTL_Z1CNT_ADDR    00000011
0x85e12030: EPB_TXFDR_CTL0_ADDR_H   00000033	0x85e12030: EPB_TXFDR_CTL1_ADDR_H   00000000
0x85e12030: EPB_TXFDR_CTL2_ADDR_H   00000031	0x85e12030: EPB_TXFDR_CTL3_ADDR_H   000000bc
0x85e12030: EPB_SMCTL_DFELTH_ADDR_H 00000001	0x85e12030: EPB_SMCTL_TLTH_ADDR_H   00000002
0x85e12030: EPB_SMCTL_ZCNT_ADDR_H   00000018	0x85e12030: EPB_SMCTL_Z1CNT_ADDR_H  00000011
0x85e12030: EPB_TXFDR_CTL0_ADDR_Q   0000002f	0x85e12030: EPB_TXFDR_CTL1_ADDR_Q   00000000
0x85e12030: EPB_TXFDR_CTL2_ADDR_Q   00000031	0x85e12030: EPB_TXFDR_CTL3_ADDR_Q   000000bc
0x85e12030: EPB_SMCTL_DFELTH_ADDR_Q 00000000	0x85e12030: EPB_SMCTL_TLTH_ADDR_Q   00000002
0x85e12030: EPB_SMCTL_ZCNT_ADDR_Q   00000018	0x85e12030: EPB_SMCTL_Z1CNT_ADDR_Q  00000011
0x85e12030: EPB_SMCTL_STARTUP_EQ2   00000000
0x85e12030: EPB_RXSET_CTL0_ADDR     00000000	0x85e12030: EPB_RXSET_PPM_ADDR      000000d0
0x85e12030: EPB_RXSET_STAT_ADDR     0000008b	0x85e12030: EPB_TXSET_CTL0_ADDR     00000000
0x85e12030: EPB_TXSET_CTL1_ADDR     00000000	0x85e12030: EPB_TXSET_LBCTL_ADDR    00000020
0x85e12030: EPB_RXLOS_RXCTL_ADDR    00000001	0x85e12030: EPB_RXLOS_TXCTL_ADDR    000000b0
0x85e12030: EPB_RXCTL_VCDLCTL3_ADDR 00000024	0x85e12030: EPB_RXCTL_BACTL_ADDR    00000008
0x85e12030: EPB_RXCTL_RXHSSTAT_ADDR 00000017
Anonymous
Re: er_bad_os and Proc_rqrd problem
The high er_bad_os counter and the port being in N8, might point to a wrong fillword setting.
Run portcfgshow to see what mode the fillword is in.
Use portcfgfillword to change the mode, this is disruptive to traffic.
Most suppliers recommend mode 3, but please consult your products vendor documentation on how the setting should be set.
Anonymous
The Proc_Rqd is a counter which means that the ASIC had to forward a frame to the CPU because it did not know what to do with it. It can be any frame that is not a data-frame. If it was a data frame and subject to zoning regulations it would have been dropped. That being said though there have been FOS defects which caused incorrectly sent dataframes to the CPU. Most of the time upgrading FOS code and bouncing the port resolves the problem.
