Contributor
different data cli switch commands and web tool
Good afternoon.
Added a new switch in Existing factory.
data cli is the same for all identical to the old and the new Switch.
SAN_Switch_2:adm> fabricshow
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
  2: fffc02 10:00:00:05:1e:05:e0:71 192.168.88.51   0.0.0.0         "SAN_Switch_2"
  3: fffc03 10:00:00:05:1e:06:bf:48 192.168.88.52   0.0.0.0         "SAN_Blade_1"
  4: fffc04 10:00:00:05:1e:5e:0d:60 192.168.88.53   0.0.0.0         "SAN_Blade_2_1"
  5: fffc05 10:00:00:05:1e:5e:0c:7f 192.168.88.54   0.0.0.0         "SAN_Blade_2_2"
10: fffc0a 10:00:00:05:1e:05:e0:0d 192.168.88.50   0.0.0.0        >"SAN_Switch_1"
The Fabric has 5 switches
different webtools data as shown in the attached files
cfgactvshow the same data on all Switchs
Valued Contributor
Re: different data cli switch commands and web tool
i trust cli. according to cli, you have 5 switches in one fabric (not factory;)
cfgactvshow also proves that the new switch was able to get the zoning configuration from other members. this would not be possible if they wouldn't form the fabric.
web tools seem to show some cosmetic defect. 2.jpg shows that san_blade_1 is the only switch in the fabric, while all others are "segmented", but at the same time san_blade_1 reports himself as subordinate. who's the principal then?..
what are the FOS versions on the switches?
Contributor
everywhere the main switch in cli
SAN_Blade_1:adm> fabricshow
  2: fffc02 10:00:00:05:1e:05:e0:71 192.168.88.51   0.0.0.0         "SAN_Switch_                                                               2"
  3: fffc03 10:00:00:05:1e:06:bf:48 192.168.88.52   0.0.0.0         "SAN_Blade_1                                                               "
  4: fffc04 10:00:00:05:1e:5e:0d:60 192.168.88.53   0.0.0.0         "SAN_Blade_2                                                               _1"
  5: fffc05 10:00:00:05:1e:5e:0c:7f 192.168.88.54   0.0.0.0         "SAN_Blade_2                                                               _2"
10: fffc0a 10:00:00:05:1e:05:e0:0d 192.168.88.50   0.0.0.0        >"SAN_Switch_                                                               1"
Firmware is the same on all switches is Fabos Version 6.2.2d
Contributor
Contributor
just noticed
Photo 1 from the computer on which and added a new switch, which usually work with. 2 photos from a computer which first went on the new switch. pictures taken simultaneously. How can this be?
Contributor
http://www.java.com/en/download/help/plugin_cache.xml
after clear the Java cache data are the same.
those obtained periodically to clear the Java cache?
Former Brocadian
Hi ngyrianova.  First off, thanks for sharing the details of what fixed your issue.  As pointed out, FOS CLI is trustworthy and its good practice, when in doubt, to verify with the CLI.  Now regarding your question, I always recommend clearing browser cache and java cache periodically.  As when new pages, content or data cannot be created (either because the cache is full or other associated problems are occurring), good house cleaning helps resolve or prevent issues such as this all together.  Should you have to do this all the time?  Every now and then definitely doesn't hurt.
Regards,
Mike Eversole
Brocade Community Manager
