Anonymous
corresponding part number of switch module
Hi,
I have a switch module part#32R1818 with FRU#32R1820. I want to know the other corresponding part number to this. I search the web and all I can see is part#32R1812 (4Gb 10-port) and part# 32R1813 (4GB 20-port). Can anyone confirm which one is 32R1818? I appreaciate any help on this.
Regards,
kaelo
External Moderator
Re: corresponding part number of switch module
18 is The Enterprise Licensed Blade
TechHelp24
Anonymous
is the 32R1818 is the brocade 4020?
External Moderator
Yesm, this is the 4020.
Enterprise Licensed enable all features in the switch, also in your case are all Port ( 20 ) Enabled, and this is the 4020
Both Blade, 4010 and 4020 are the same Hardware, but different Licensed.
TechHelp24
Anonymous
does it mean the corresponding part number for this is below? which is the 20-port?
I really appreciate your assistance.
Regards,
kaelo
External Moderator
Kaelo,
long story.....
32R1813 is genuine the 4010 also Entry Level Licensed only 10 Port enabled No full Fabric
32R1818 is Genune the 4020 also Enterpise Licensed all Pot enable Full Fabric
Again, both blade are the same hardware, and theoretically have the Label 13 or 18 not any signification.
Another example, you have purchased a Blade 32R1813 also 4010 and upgrade later the License from Entry Level to Enterprise.
TechHelp24
Anonymous
thanks, makes sense to me now. Thanks a lot for your help.
regards,
kaelo
