Anonymous
connect 2 SAN Switches over Multiplexer
Hi Experts ,
Is there any way to configure the connectivity between 2 SAN Brocade Switches in Different sites ?
BR
Anonymous
Re: connect 2 SAN Switches over Multiplexer
The distance is 250 KM
External Moderator
this is a simple ISL over xWDM
TechHelp24
Anonymous
It's over xWDM , "Multiplexer "
Former Brocadian
... can I ask what switches you are administering for this distance and what each FOS version they are running?  The reason I ask, certain things are enabled/disabled depending on this information.  From there, we can advise how to proceed.
Regards,
Mike Eversole
Brocade Community Manager
Anonymous
Dears Mike and TechHelp24 ,
Thanks alot for your reply .
please find the details for bith switches
Site A:
Switch Name :fer_fabri_a
Switch O.S :V6.4.1b
Domain ID:129
Chassis name :Brocade_DCX
Site B:
Switch Name :AsiaCell_Fabric_A
Switch O.S :v6.4.3b
Domain ID:120
Chassis name :ED_DCX_4S_B
distance between both sites is 250 KM
I would hieghly appreciate your help .
BR
Anonymous
Dears ,
Any update , can you advice ?
BR
Valued Contributor
Hi,
In order to connect those two switchs, you can do it via DWDM (or CDWM). On the switchs side, you need to have the Fabric and the Extended Fabric licenses on both switchs.
Kind regards,
Felipon
Anonymous
I am going to use the following :-
configue the port as follows :-
1-portcfgqos --disable port
2-disable the credit recovery port
3-portcfglongdistance port,LD,1
Anonymous
both licenses are installed
