Contributor
configupload problems on DCX
Hello,
  I am trying to upload config from a DCX switch to a linux server. The problem is that when I run configupload, I choose scp or sftp, it doesn't give me a prompt for the password. It just tries to go ahead and connect to the server without asking for passwd and it fails. I checked a few old posts . I read about the cfgsecure setting, however when I run configshow | grep -i cfgload, it doesn't return anything. Also I read about setting the cfgload parameters using configure command. However, it doesn't give me an option to configure the cfgload parameters. The version running is 7.0.0.c . Any help would be appreciated.
Moeen
