New Contributor
Accepted Solution
can i connect G620 QSFP to X6-4B core blade
we have new bought G620 and X6-4, can we connect QSFP of G620 to X6-4 core blade?
from Brocade documenation, X6-4 core blade only support X6-4 interconnect or x6-4 and 8510, it doesn't mention G620 switches.
External Moderator
Re: can i connect G620 QSFP to X6-4B core blade
@lxb2008
No, this is not supported.
Howerver I've submitted to Brocade months ago a RFE for exact what you ask.
TechHelp24
New Contributor
thanks, Antonio,  so the only option is to use switch FC ports of both G620b and X6-4b to create ISL for uplink?
External Moderator
unfortunately yes, this is at the moment the only traditional options to use ISL/Trunking
as saied, I've submited a concept to Brocade how such a features can be realized, is not simple....
I'll try to push and post here as soon I get any feedback from PM or Developer Team.
Stay Tuned!
Antonio
TechHelp24
