Anonymous
can I use core PID format when use 48-port blade with DCX or 48000
  When I use 48-port blade with 48000 or DCX, the area id of ports in 48-port blade will not be unique, if we use CORE PID format, the 2nd 8 bit of PID (0x01xx00) will can not cover port 32-47(because area id of these ports will beyond 255 ), then what PID format can we used in this environment? thank you!
Anonymous
Re: can I use core PID format when use 48-port blade with DCX or 48000
Hi liuchuanwen,
Core PID is the only format supported in this case. While Area byte won't be unique the difference is in Port/ALPA byte: 0x00XX00 vs 0x00XX80
Hope this helps,
Linar
