Anonymous
brocade5100 ISL 5300 E-Port segmented,(Op Mode incompat)
5100 configshow:
fabric.domain:1
fabric.ididmode:0
fabric.ops.BBCredit:16
fabric.ops.E_D_TOV:2000
fabric.ops.R_A_TOV:10000
fabric.ops.dataFieldSize:2112
fabric.ops.max_hops:7
fabric.ops.mode.fcpProbeDisable:0
fabric.ops.mode.isolate:0
fabric.ops.mode.longDistance:0
fabric.ops.mode.noClassF:0
fabric.ops.mode.pidFormat:1
fabric.ops.mode.tachyonCompat:0
fabric.ops.mode.unicastOnly:0
fabric.ops.mode.useCsCtl:0
fabric.ops.vc.class.2:2
fabric.ops.vc.class.3:3
fabric.ops.vc.config:0xc0
fabric.ops.vc.linkCtrl:0
fabric.ops.vc.multicast:7
fabric.ops.wan_tov:0
DS_5100B_DOWN:FID128:admin> portcfgshow 31       //E-port show
Area Number:              24
Speed Level:              AUTO(HW)
Fill Word:                0(Idle-Idle)
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
NPIV capability           ON
QOS E_Port                AE
Port Auto Disable:        OFF
Rate Limit                OFF
EX Port                   OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
errdump:
2012/04/10-09:13:27, , 3878, FID 128, WARNING, DS_5100B_DOWN, port 31, incompatible flow control parameters (2)
5300 configshow:
fabric.domain:15
fabric.ficonmode:0
fabric.fidcheckdisable:0
fabric.hifmode:0
fabric.ididmode:0
fabric.ops.bladeFault_on_hwErrlevel:0
fabric.ops.mode.longDistance:1
swd77:admin> portcfgshow 48    //E-port show
Area Number:              48
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                AE
Rate Limit                OFF
EX Port                   OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
Fault Delay:              0(R_A_TOV)
NPIV PP Limit:            126
CSCTL mode:               OFF
This is 5100 and 5300 config info,I don't find differ.
Valued Contributor
Re: brocade5100 ISL 5300 E-Port segmented,(Op Mode incompat)
Anonymous
Thats one difference I spotted aswell.
They other difference might be one switch running in VF mode and the other isn't.
If one switch is IN and the other is NO IN VF mode, it's not a big deal.
If both switches are in VF, make sure you have configured the same Fabric ID for you Logical switches.
Th 5100 seems to have at least (default) FID 128 present
Anonymous
I have anthor ISL switch between fabric option "fabric.ops.mode.longDistance:0 and 1" not found last problem,this fabric's domain id is differently.
External Moderator
Jiawen, you post
--->>> This is 5100 and 5300 config info,I don't find differ.
I see different output in both 5100 and 5300 configshow, you shold check with command "configure" switch paramaters.
5100 configshow:
fabric.domain:1
fabric.ididmode:0
trunkated------
5300 configshow:
fabric.domain:15
fabric.ficonmode:0
fabric.hifmode:0
fabric.ididmode:0
trunkated------
TechHelp24
Anonymous
Hi All.
What is the default setting of "fabric.ops.mode.longDistance: 0 0r 1 "  although my switch is ISL mode.. with only one port.
Frequent Contributor
[ Edited ]
AFAIK the "sameness" check is for fabric.ops parameters, not for all fabric parameters. As long as you don't actually run hifmode, the three parameters you highlighted shouldn't make a difference.
The default for fabric.ops.mode.longDistance is 0. That parameter was made obsolote a long time ago. With all switches in the field you can set the longdistance mode for each port individually. But the "switch-wide" parameter is still a fabric.ops parameter (=> needs to be the same in all switches) and so it was kept in the config for legacy reasons... so that older switches would let newer switches join the fabric).
