Anonymous
brocade 5100 switch how many ASIC for 40 ports
I read through the data sheet of 5100 but I could not get a answer on the number of ASIC in 5100.
I have gone through some of the previous posts here and it says all 40 ports are in one ASIC.
Do we have any documentation on it  ? Or if some one can put a screenshot of it would be helpful
The main reason is I to need to design a solution and it must be local switching.
Thanks in Advance.
External Moderator
Re: brocade 5100 switch how many ASIC for 40 ports
--->>>...not get a answer on the number of ASIC in 5100
Brocade 5100 is designed on a Single Condor2 ASIC
TechHelp24
Valued Contributor
hi brocadehelp, your question is already answered, and the answer provided by TechHelp24 is not just "helpful" -- it is 100% "correct" one.
Anonymous
thanks Techhelp24 and alexey ... I am also looking if anyone can help me find a brocade document where this is mentioned.
Anonymous
In 5100's Brocade datasheet :
"The Brocade 5100 utilizes sixth-generation ASIC technology featuring five 8-port groups. "
As it has only 40 ports, you may conclude there's only one ASIC.
Kind regards,
david
Anonymous
Thanks david
