Anonymous
brocade 4gb ibm blade
Hi all.
i use an IBM blade with two brocade 4gb FC. I use this switch as passthrough, i use two san FC switchs Mc data.
I have to add a new server (lame ibm) and connect it to the EMC SAN CX3-20c.
Zoning is done in Mc data switchs, I have nothing to do with brocade switch, they can learn the news zones.
However  I have an issue, only one zone is OK in the brocade switch the second appears in Effective configuration: cfg:.
The good zone appears in Effective configuration: name_zone.
I have the same problem in the 2 brocade switchs from my IBM blade.
I have another blade (the same) I had add the 2 zones in the mc data and automatically the news zones appear in the brocade and no trouble between server an d SAN.
Any ideas?
Thanks
Alex
External Moderator
Re: brocade 4gb ibm blade
Alex,
--->> I have the same problem in the 2 brocade switchs from my IBM blade.
--->> I have another blade (the same) I had add the 2 zones in the mc data and automatically the news zones appear in the brocade and no trouble between server
1) McDATA Firmware Release ?
2) Brocade Fabric OS Release ?
3) Which Interop-Mode is current set both Switches McDATA's and Brocade ?
4) Which DomainID's ?
5) Are all Switch Parameter's in Brocade correct Set ?
6) Output's "switchshow" command from Brocade Blade
TechHelp24
Anonymous
Switch 1:
Switch Information Report for brocade4Gb
List of Switches
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
97: fffc61 10:00:00:05:1e:05:9c:f3  192.168.3.125   0.0.0.0         "brocade4Gb"
98: fffc62 10:00:08:00:88:e3:93:97                                >
The Fabric has 2 switches
Current Switch Information
Ethernet IP Address: 192.168.3.125
Ethernet Subnetmask: 255.255.255.0
Fibre Channel IP Address: 0.0.0.0
Fibre Channel Subnetmask: 0.0.0.0
Gateway Address: 192.168.3.10
Kernel:     2.4.19
Fabric OS:  v5.0.5a
Made on:    Tue Jul 18 21:12:26 2006
Flash:        Sat Jul 7 04:29:43 2007
BootProm:   4.5.2
List of Inter-Switch Links
Local Domain ID: 97
Local Port     Domain     Remote Port     State
    15         98           2    NB_ST_FULL
List of Ports
switchName:    brocade4Gb
switchType:    37.1
switchState:    Online
switchMode:    Interop
switchRole:    Subordinate
switchDomain:    97
switchId:    fffc61
switchWwn:    10:00:00:05:1e:05:9c:f3
zoning:            ON (ESX5_SPB1)
switchBeacon:    OFF
Area Port Media Speed State
  0   0   --    N4   No_Module
  1   1   cu    N4   Online    F-Port  21:00:00:1b:32:04:56:95
  2   2   cu    N4   Online    F-Port  21:00:00:1b:32:04:ef:97
  3   3   cu    N4   Online    F-Port  21:00:00:1b:32:87:f7:b4
  4   4   cu    AN   No_Sync
  5   5   cu    AN   No_Sync
  6   6   cu    AN   No_Sync
  7   7   cu    AN   No_Sync
  8   8   cu    AN   No_Sync
  9   9   cu    AN   No_Sync
10  10   cu    AN   No_Sync
11  11   cu    AN   No_Sync
12  12   cu    N4   Online    F-Port  21:00:00:1b:32:04:1f:96
13  13   cu    N4   Online    F-Port  21:00:00:1b:32:04:b8:97
14  14   cu    AN   No_Sync
15  15   id    N4   Online    E-Port  10:00:08:00:88:e3:93:97 (upstream)
16  16   id    N4   No_Light
17  17   --    N4   No_Module
18  18   --    N4   No_Module
19  19   --    N4   No_Module
Name Server
  610100 610200 610300 610c00 610d00 620013 620113 620313
  620413 620513 620613
11 Nx_Ports in the Fabric }
Type Pid    COS     PortName                NodeName                 TTL(sec)
N    610100;      3;21:00:00:1b:32:04:56:95;20:00:00:1b:32:04:56:95; na
    FC4s: FCP
    NodeSymb: "QMI3472 FW:v4.00.18 DVR:v7.07.04.2vmw"
    Fabric Port Name: 20:01:00:05:1e:05:9c:f3
    Permanent Port Name: 21:00:00:1b:32:04:56:95
N    610200;      3;21:00:00:1b:32:04:ef:97;20:00:00:1b:32:04:ef:97; na
    FC4s: FCP
    Fabric Port Name: 20:02:00:05:1e:05:9c:f3
    Permanent Port Name: 21:00:00:1b:32:04:ef:97
N    610300;      3;21:00:00:1b:32:87:f7:b4;20:00:00:1b:32:87:f7:b4; na
    FC4s: FCP
    Fabric Port Name: 20:03:00:05:1e:05:9c:f3
    Permanent Port Name: 21:00:00:1b:32:87:f7:b4
N    610c00;      3;21:00:00:1b:32:04:1f:96;20:00:00:1b:32:04:1f:96; na
    FC4s: FCP
    NodeSymb: "QMI3472 FW:v4.00.26 DVR:v9.1.4.15"
    Fabric Port Name: 20:0c:00:05:1e:05:9c:f3
    Permanent Port Name: 21:00:00:1b:32:04:1f:96
N    610d00;      3;21:00:00:1b:32:04:b8:97;20:00:00:1b:32:04:b8:97; na
    FC4s: FCP
    Fabric Port Name: 20:0d:00:05:1e:05:9c:f3
    Permanent Port Name: 21:00:00:1b:32:04:b8:97
The Local Name Server has 5 entries }
Zoning Information
Defined configuration:
no configuration defined
cfg:    ESX5_SPB1
zone:    ESX1LAB_SPAO
        50:06:01:60:41:e0:72:a8
zone:    ESX1LAB_SPB1
        50:06:01:69:41:e0:72:a8
zone:    ESX1_SPA0
zone:    ESX1_SPB1
zone:    ESX2LAB_SPA0
        21:00:00:1b:32:04:c5:95
zone:    ESX2LAB_SPB1
zone:    ESX2_SPA0
zone:    ESX2_SPB1
zone:    ESX5_SPA0
zone:    SNC_HBA1_NBU_HBA1
        20:01:00:30:8c:03:63:03
        21:00:00:e0:8b:81:4c:72
zone:    VCB_SPA0
zone:    VCB_SPB1
zone:    csamiens_DM2_P1_SPA_P4_CK200073800287
        50:06:01:61:41:e0:76:ed
zone:    csamiens_DM2_P1_SPB_P5_CK200073800287
zone:    csamiens_DM3_P0_SPA_P4_CK200073800287
        50:06:01:68:41:e0:76:ed
zone:    csamiens_DM3_P0_SPB_P5_CK200073800287
SFP Serial ID Information
port  0: --
port  1: cu
port  2: cu
port  3: cu
port  4: cu
port  5: cu
port  6: cu
port  7: cu
port  8: cu
port  9: cu
port 10: cu
port 11: cu
port 12: cu
port 13: cu
port 14: cu
port 15: id (sw) Vendor: FINISAR CORP.    Serial No: PBQ0BRW
port 16: id (sw) Vendor: FINISAR CORP.    Serial No: PBP41QR
port 17: --
port 18: --
port 19: --
Swicth2:
Switch Information Report for brocade4GbThe problème
List of Switches
97: fffc61 10:00:00:05:1e:05:9c:99  192.168.3.126   0.0.0.0         "brocade4Gb"
98: fffc62 10:00:08:00:88:e3:93:32                                >
Ethernet IP Address: 192.168.3.126
Kernel:     2.4.19
Fabric OS:  v5.0.5a
Flash:        Sat Jul 7 04:59:08 2007
BootProm:   4.5.2
Local Domain ID: 97
    15         98           2    NB_ST_FULL
List of Ports
switchType:    37.1
switchState:    Online
switchMode:    Interop
switchDomain:    97
switchId:    fffc61
switchWwn:    10:00:00:05:1e:05:9c:99
zoning:            ON (ESX5_SPB0)
switchBeacon:    OFF
  0   0   --    N4   No_Module
  1   1   cu    2G   Online    F-Port  21:01:00:1b:32:24:56:95
  2   2   cu    2G   Online    F-Port  21:01:00:1b:32:24:ef:97
  3   3   cu    N4   Online    F-Port  21:01:00:1b:32:a7:f7:b4
  4   4   cu    AN   No_Sync
  5   5   cu    AN   No_Sync
  6   6   cu    AN   No_Sync
  7   7   cu    AN   No_Sync
  8   8   cu    AN   No_Sync
  9   9   cu    AN   No_Sync
10  10   cu    AN   No_Sync
11  11   cu    AN   No_Sync
12  12   cu    N4   Online    F-Port  21:01:00:1b:32:24:1f:96
13  13   cu    N4   Online    F-Port  21:01:00:1b:32:24:b8:97
14  14   cu    AN   No_Sync
15  15   id    N4   Online    E-Port  10:00:08:00:88:e3:93:32 (upstream)
Name Server
  620413
9 Nx_Ports in the Fabric }
N    610100;      3;21:01:00:1b:32:24:56:95;20:01:00:1b:32:24:56:95; na
    FC4s: FCP
    Fabric Port Name: 20:01:00:05:1e:05:9c:99
    Permanent Port Name: 21:01:00:1b:32:24:56:95
N    610200;      3;21:01:00:1b:32:24:ef:97;20:01:00:1b:32:24:ef:97; na
    FC4s: FCP
    Fabric Port Name: 20:02:00:05:1e:05:9c:99
    Permanent Port Name: 21:01:00:1b:32:24:ef:97
N    610300;      3;21:01:00:1b:32:a7:f7:b4;20:01:00:1b:32:a7:f7:b4; na
    FC4s: FCP
    Fabric Port Name: 20:03:00:05:1e:05:9c:99
    Permanent Port Name: 21:01:00:1b:32:a7:f7:b4
N    610c00;      3;21:01:00:1b:32:24:1f:96;20:01:00:1b:32:24:1f:96; na
    FC4s: FCP
    Fabric Port Name: 20:0c:00:05:1e:05:9c:99
    Permanent Port Name: 21:01:00:1b:32:24:1f:96
N    610d00;      3;21:01:00:1b:32:24:b8:97;20:01:00:1b:32:24:b8:97; na
    FC4s: FCP
    Fabric Port Name: 20:0d:00:05:1e:05:9c:99
    Permanent Port Name: 21:01:00:1b:32:24:b8:97
Zoning Information
cfg:    ESX5_SPB0
zone:    ESX1LAB_SPA1
        50:06:01:61:41:e0:72:a8
zone:    ESX1LAB_SPB0
        50:06:01:68:41:e0:72:a8
zone:    ESX1_SPA1
zone:    ESX1_SPBO
zone:    ESX2LAB_SPA1
        21:01:00:1b:32:24:c5:95
zone:    ESX2LAB_SPB0
zone:    ESX2_SPA1
zone:    ESX2_SPB0
zone:    ESX5_SPA1
zone:    VCB_SPA1
zone:    VCB_SPB0
zone:    csamiens_DM2_P0_SPA_P5_CK200073800287
        50:06:01:60:41:e0:76:ed
zone:    csamiens_DM2_P0_SPB_P4_CK200073800287
zone:    csamiens_DM3_P1_SPA_P5_CK200073800287
        50:06:01:69:41:e0:76:ed
zone:    csamiens_DM3_P1_SPB_P4_CK200073800287
port  0: --
port  1: cu
port  2: cu
port  3: cu
port  4: cu
port  5: cu
port  6: cu
port  7: cu
port  8: cu
port  9: cu
port 10: cu
port 11: cu
port 12: cu
port 13: cu
port 14: cu
port 15: id (sw) Vendor: FINISAR CORP.    Serial No: PBP40X4
port 16: id (sw) Vendor: FINISAR CORP.    Serial No: PBQ0EUN
port 17: --
port 18: --
port 19: --
The problem is with ESX5.
switch1:
brocade4Gb:root> switchShow
switchType:     37.1
switchState:    Online
switchMode:     Interop
switchDomain:   97
switchId:       fffc61
switchBeacon:   OFF
  0   0   --    N4   No_Module
  4   4   cu    AN   No_Sync
  5   5   cu    AN   No_Sync
  6   6   cu    AN   No_Sync
  7   7   cu    AN   No_Sync
  8   8   cu    AN   No_Sync
  9   9   cu    AN   No_Sync
10  10   cu    AN   No_Sync
11  11   cu    AN   No_Sync
14  14   cu    AN   No_Sync
swicth2
brocade4Gb:root> switchshow
switchType:     37.1
switchState:    Online
switchMode:     Interop
switchDomain:   97
switchId:       fffc61
switchBeacon:   OFF
  0   0   --    N4   No_Module
  4   4   cu    AN   No_Sync
  5   5   cu    AN   No_Sync
  6   6   cu    AN   No_Sync
  7   7   cu    AN   No_Sync
  8   8   cu    AN   No_Sync
  9   9   cu    AN   No_Sync
10  10   cu    AN   No_Sync
11  11   cu    AN   No_Sync
14  14   cu    AN   No_Sync
Thanks.
If you want something else you can ask me.
External Moderator
Alex,
--->>> The problem is with ESX5.
ESX 5, your mean VMWare ?
I believe, I'm no 100% sure, Fabric OS 5.0.x ( is very old ) , is not Supported for ESX 5
--->>> If you want something else you can ask me.
which exact Firmware release is Loaded in the McDATA ?
TechHelp24
Anonymous
ESX5 is the hostname. I use VMware ESX Server 3.02. It is the same FW as in the brocade where it works.
Mc DATA1:
Firmware 09.02.00 8
Domain ID 2
Mc DATA2:
Firmware 09.02.00 8
Domain ID 2
where it works I have an older version of mc data:  08.00.01 2
Thanks
External Moderator
Eric,
This both McDATA Switches 1 and 2 are in the same fabric ? I ask why, both switch have the same Domain ID.
Two switch whit the same ID in the same Fabric can not Operated.
Mc DATA1:
Firmware 09.02.00 8
Domain ID 2
Mc DATA2:
Firmware 09.02.00 8
Domain ID 2
TechHelp24
Anonymous
I confirm it works with my others lames and zone.
I have a problem only with the new lame and new zone very strange.
Anonymous
No ideas?
Thanks
Anonymous
I notice that:
3. 125 :
  0   0   --    N4   No_Module
3. 126 :
  0   0   --    N4   No_Module
For ports 1 and 2 the speed is different (N4 and 2G), is it necessary to change port3 (where my new lame is) on the second switch to 2G?
Could it resolve my issue?
Thanks
Alex
External Moderator
I,am ignorant.
what is "lame" ?
TechHelp24
