Anonymous
brocade 300 work with brocade 200e
we have a pair of 200e fc switch. Recently, one of the switch fail. And this model is no longer avaliable. Therefore, we only have the option to buy a brocade 300 for replacement.
The currently topoloty is as below:
The firmware version for 200e and 300 will be different. I am wondering if there any issue to simply replace with a brocade 300.
Thank!
External Moderator
Re: brocade 300 work with brocade 200e
For details about Compatibility beetwen two different FabOS release, refer the Release note from the current release is Loaded in the 300.
TechHelp24
Anonymous
As there is no interconnection between 2 switch, I am wondering if the different firmware/FOS will cause any potientail problem.
Thanks!
Anonymous
Hi joeng
Seeing as you have no seperate Fabrics you can run both switches with the different version of Fabric OS , but I would personally get the both up to the same levels , or as close as possible.
David
Anonymous
so that means brocade 300 can be clustered with 200E if both has the compatible FabOS ?
