Anonymous
brocade 300 firmware 6.3.1a
  hi, i am new to updating these brocades, i usually to all the HP updates but i now have to look at taking over the updates of the fibre switches.
i have looked but cant seem to find a site by model that lists the firmware and its release dates.
I also would like to try a find a upgrade matrix if they do one?
thanks
External Moderator
Anonymous
Re: brocade 300 firmware 6.3.1a
hi thanks for that.
from reading the docs it does not really show you what upgrade paths are supported which is really what i am more looking for.
for example can i go from 6.3.1a straight to 7.0.2c
thanks
External Moderator
FOS upgrade is supported from your current 6.3.x -> 6.4.x then you can upgrade to 7.0.x
If you want to upgrade to latest Release 7.1.1, refer Release Notes for details.
TechHelp24
Anonymous
FOS on  Brocade 300 you can upgrade to 7.2.0a
