New Contributor
between 2 DCX switches, 2 trunks (trunk1 with 3 ISLs, trunk2 with 1 ISL). what would happen?
Hi there,
this is current situation in my environment which I found out. Of course I would like to corrected as 2 trunks, each trunk has 2 ISLs.
But just curious, if I don't correct now, what is the impacts? how brocade route the traffic between those 2 trunks? each ISL is 8Gb.
would dcx split thr traffic 3:1 between those 2 trunks? or 1:1?
Could some gurus advise me? thanks in advance!
Charles
External Moderator
Re: between 2 DCX switches, 2 trunks (trunk1 with 3 ISLs, trunk2 with 1 ISL). what would happen?
[ Edited ]
look in the Admin Guide for DLS = Dynamic Load Sharing
what you exactely mean with:
-->>....trunk2 with 1 ISL
is a bit confused, Trunking with 1 ISL cannot be created.
can you please explain a bit more ?
TechHelp24
