Anonymous
b 6510 temp and fan speed
Hi,
Brocade B 6510,
Do you know if there are any charts that show thresholds of at what temperature the fan speed should be at?
And what is the tempshow threshold limit for this switch?
Regards,
Niklesh Reddy
Valued Contributor
Re: b 6510 temp and fan speed
Hi there,
Take a look at the 6510 datasheet :
http://www.brocade.com/downloads/documents/data_sheets/product_data_sheets/6510-switch-ds.pdf
Rgds,
Felipon
