Occasional Contributor
Accepted Solution
aaaConfig not doing anything ?
Hi,
I'm setting up the remote authentication on our SAN Switches, but on 4 of them (switchtype 148.0) with FOS v8.0.2b, the aaaConfig command doesn't give me any error, but the radius config is not saved :
SWITCH:FID112:admin> aaaconfig --show
RADIUS CONFIGURATIONS
RADIUS configuration does not exist.
LDAP CONFIGURATIONS
LDAP configuration does not exist.
TACACS+ CONFIGURATIONS
TACACS+ configuration does not exist.
Primary AAA Service: Switch database
Secondary AAA Service: None
SWITCH:FID112:admin> aaaConfig --add radius01.mynetwork.net -conf radius -p 1812 -s "blabla" -a pap
LDAP CONFIGURATIONS
Nothing in errdump, didn't find anything in the defect of the FOS version, tried the command from within different virtual fabrics, from root user, checked that network flows are allowed on the firewall ...
Any idea ? :/
Thanks !
Broadcom Moderator
Re: aaaConfig not doing anything ?
Hello,
You should run the command on Chassis context.
Hello Thierry,
The command is ran on the default switch, I have same results on the other virtual switch :
SWITCH:FID112:admin> lscfg --show
Created switches FIDs(Domain IDs):  112(ds)(199)  125(115)
Port      0     1     2     3     4     5     6     7     8     9
FID     125 | 125 | 112 | 112 | 112 | 112 | 112 | 112 | 112 | 112 |
Port     10    11    12    13    14    15    16    17    18    19
FID     112 | 112 | 112 | 112 | 112 | 112 | 112 | 112 | 112 | 112 |
Port     20    21    22    23    24    25    26    27    28    29
FID     112 | 112 | 112 | 112 | 112 | 112 | 125 | 125 | 112 | 112 |
Port     30    31    32    33    34    35    36    37    38    39
FID     112 | 112 | 112 | 112 | 125 | 125 | 112 | 112 | 112 | 112 |
Port     40    41    42    43
For an (still) unknown reason, it worked with IP instead of FQDN, even tho we are able to ping from the switch using the FQDN of the radius server ...
Solved.
Regular Contributor
There seem to be a few snags with FQDN especially when the switch has issues resolving that name. Has DNS been set up properly and is it possible for the switch to communicate both udp and tcp over port 53 to that DNS server?
Just wondering.
Kind regards,
Erwin van Londen
Brocade Distinguished Architect
http://www.erwinvanlonden.net The Fibre Channel blog
Q&A -> https://hackhands.com/elo/
Yes DNS was set up, but not sure TCP/UDP flows were properly opened ...
