Turn on suggestions
Showing results for
09-13-2013 05:14 PM
Hello,
Why does this 7800 does not ping to lan gateway? I am pretty sure is not the switch nor the cable.
Thanks.
Bogota:admin> portcmd --ping ge0 -s 10.227.100.21-d 10.227.100.3 -d 10.227.100.3
Pinging 10.227.100.3 from ip interface 10.227.100.21 on 0/ge0 with 64 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping Statistics for 10.227.100.3:
Packets: Sent = 4, Received = 0, Loss = 4 (100 percent loss)
ipsd (pid=1049): signal=13
