Occasional Contributor
What is the recommended model for mid-range storage array?
[ Edited ]
It's been a while since last time I used Brocade SAN swithc. Can anybody please recommended a Brocade model for NetApp cluster filers? We have 6 nodes cluster and they are FAS 8080.
Also, what is the version of recent OS?
Looking forward to hear you!
Broadcom Moderator
Re: What is the recommended model for mid-range storage array?
Mid-range would likely be a G610 or G620. This would future-proof your data needs for quite a while.
http://www.brocade.com/en/products-services/storage-networking/fibre-channel/g620-switch.html
http://www.brocade.com/en/backend-content/pdf-page.html?/content/dam/common/documents/content-types/datasheet/brocade-g620-switch-ds.pdf
If you want to save some money, and still get 16G speeds, you can go with one of the 65xx switch family:
http://www.brocade.com/en/products-services/storage-networking/fibre-channel/6510-switch.html
Both will run FOS 8.0.x, or 8.1.x. The next release coming out this fall is 8.2.x
I don't know anything about the latest NetApp, but they may be limited to 16Gb speeds. The 65xx switch in pairs for redundancy will surely give you all the BW you need.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
