Occasional Contributor
Accepted Solution
What is the difference between 8Gb 10Km SFP P/N 57-1000027-01 and 57-1000027-02?
C
Broadcom Moderator
Re: What is the difference between 8Gb 10Km SFP P/N 57-1000027-01 and 57-1000027-02?
Hi Dave ,
 the 57-1000027-01 is EOL since 11/2013 , this part, for us, is systematically replaced by the new one ref 57-1000027-02
Regards
Jerome
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided
solely as a convenience for Brocade customers. All systems and all networks are different and unique.
If you have a service affecting network problem, please open a TAC service request for service through
Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, please
mark it with the button at the bottom "Accept as solution".
Hi Jerome,
Thanks.  So they are functinoally the same?  Do you know why the -01 was EOL if there is no difference?
Thanks,
Dave
Broadcom Moderator
Hi Dave ,
Their functionalitys are the same there is no difference .
The -02 are just the last ones out of factory and qualified . Brocade will continue to provide support for previously qualified transceiver/switch combinations for customers with valid support contracts.
Regards
Jérôme
