Anonymous
What cable to connect switche Silkworm 200E to HP MSL4048
Hello,
I want to connect a HP Library MSL4048 to a SAN via a switche Silkworm 200E, but I don't find
the type of cable needed to do it.
Can you give me this information.
Thanks.
AL
Anonymous
Re: What cable to connect switche Silkworm 200E to HP MSL4048
Most probably you're looking for an OM2 (or 3) LC-LC cable if you're MSL has FC drives.
Look your desired lenght up in the quickspecs  http://h18000.www1.hp.com/products/quickspecs/13258_div/13258_div.html#Related%20Options under optical cables
External Moderator
In some circumsatnce the issue is not caused by wrong Cable, but most probable by wrong set and/or definied Port Mode, and this should be configured as Loop Mode instead to ALPA Mode or vice-versa.
Check the Switch Port config with the Tape Port Config, and if required set the correct Topology.
If you are satisfied with the responses please mark and "Rate" as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
TechHelp24
