Anonymous
Web Tools does not show Zone Configuration
Hi,
Web Tools does not show any zone information (aliases, zones and configs).
I can see all the zone configuration and even modify it vi telnet.
Brocade 5000 with v6.1.0d.
Thanks for you help.
David Ulloa
Anonymous
Re: Web Tools does not show Zone Configuration
Hi David
What user account did you use to login , sounds like your account does not have the correct "fabric admin" privileges.
Regards
David
External Moderator
Some feature are not lomger available / visible in Web -Tools.
You need DCFM ( Prof is for Free ) in order to see Display, because this was mooved in DCFM.
TechHelp24
Anonymous
An other way is to use the CLI (telnet or SSH) for the zoning stuff.
Check the command zonehelp for more details.
If you would like to create an alias, a zone and make it a member of the active configuration you need following commands:
alicreate "aliname","wwn"
zonecreate "zonename","WWN1;WWN2"
cfgadd cfgname,zonename
cfgsave
cfgenable cfgname
Andreas
PS: cfgactvshow --> is good to check if a wwn is part of the active cfg. In newer FOS codes you can use  the UNIX pipe grep commands for easy searching....  But I am not sure if it is possible in FOS 6.1 with normal Admin rights.
Anonymous
Thanks all for your comments.
I have used the "admin" account. Using telnet (CLI) works ok but customer prefers to use Web Tools.
As far as I known the basic zoning configuration is still available in Web Tools, am I right?
Best regards,
David
Anonymous
As Techhelp24 mentioned some of the features have been moved to DCFM.
But I find the zoning features back in 6.4.1 version of Webtoools and have used it effectively for one customer.
Try upgrading the FOS to this level and let us know if it helps.
