Anonymous
Web Management interface inaccessible on Brocade SilkWorm 200E fibre switch
We recently moved a Brocade SilkWorm 200E fibre switch to a new VLAN in our Data Centre.  After the move, the web interface is not accessible anymore.  I can ping the management NIC on the switch, so I know it is online.  I think this may be due to some ACLs on the new network/VLAN.
There are ACLs to allow Ping, HTTP, and HTTPS through.  I'm thinking the ACLs block whatever port the Java switch management uses, but I can not find what port this is in any documentation.
Does anyone know which port the Java switch management app uses?
Anonymous
Re: Web Management interface inaccessible on Brocade SilkWorm 200E fibre switch
Hi,
are you able to login via ssh or telnet on that switch?
I think a ping test is only useful if you know that the switch IP address on the new VLAN was free and unused before you moved the switch.
As far as I know is that you only need from client to switch:
Port 22  TCP SSH SCP
Port 23 TCP Telnet
Port 80 TCP HTTP
Port 443 TCP HTTPS
Port 161 UDP SNMP
From switch to destination
Port 20 & 21 TCP FTP
Port 123 UDP NTP
Port 1812 UDP RADIUS
Port 1813 UDP RADIUS
As far as I know there are no Java ports required.
A client to DCFM is using some other ports but not the plain Webtools.
I think the best way to get out of this issue is to ask the network/firewall admin to have a look in the log files which sessions are rejected.
Best regards,
Andreas
