New Member
Web GUI giving: System is busy now
when accessing a brocade switch I'm getting the following error:
System is busy now.
Please try after some time.
any help please.
Thanks
Broadcom Moderator
Re: Web GUI giving: System is busy now
Hi,
CPU is loaded, possible? Are you running FOS 8.1.xy version of code? Are you using https or not? Can you login via ssh?
kind regards
