Turn on suggestions
Showing results for
02-06-2015 09:27 AM
Can anyone explain what the error codes mean on sfpshow command output please.
I didn't find any documentation on those.
We have ports with these outputs:
Alarm flags[0,1] = 0x5, 0x40
Warn Flags[0,1] = 0x5, 0x40
And on the other end these:
Alarm flags[0,1] = 0x5, 0x00
Warn Flags[0,1] = 0x5, 0x00
Regards.
02-10-2015 06:23 AM
