Anonymous
Warning Env Fan 2, is below low boundary(High=3400, Low=1600). Current value is 0 RPM
I found this message from SAN Silkworm 48000. this message is send from fabric event. Please,help me suggest me how should I do anything.
thanks
External Moderator
Re: Warning Env Fan 2, is below low boundary(High=3400, Low=1600). Current value is 0 RPM
nanosec,
probable is here the FAN 2 ( Middle Fan ) bad. Remove the FAN and reinserted again.
Check this fan by another slot 1 or 3. If you get a same error, the FAN must be replaced.
TechHelp24
TechHelp24
