Occasional Contributor
Virtual Fabric enabled on two switches
I was going to upgrade FOS today from 7.3.1 to 7.4.2c and two of the switches a 5300 and a 5100 are not listed by name if I try to use Firmware repository under CMCNE. (BNA)  I see them available under chassis name but not switchname.  These two switches have VF enabled on them.  We do not use this feature and not sure how virtual fabric got enabled on these two.
Was planning to disable the VF first and then attempt the upgrade.  If I disable the VF other than the swtich reboots will I lose anthing else?  WIll the trunking remain in place?  Zoning is affected?
Thanks in advance.
External Moderator
Re: Virtual Fabric enabled on two switches
[ Edited ]
@ddywz
1) VF as per Default is not enable
2) enable or disable VF is disruptive an required a reboot
-->> If I disable the VF other than the swtich reboots will I lose anthing else?
3) if all zoning, ISL, or whatever are in base Switch - by default 128 - then the config in base switch will not be lost
4) command "lscfg --show" give the output of configured VF
TechHelp24
The output of that command shows this:
Created switches FIDs(Domain IDs):  128(ds)(2)
Port      0     1     2     3     4     5     6     7     8     9
FID     128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
Port     10    11    12    13    14    15    16    17    18    19
Port     20    21    22    23    24    25    26    27    28    29
Port     30    31    32    33    34    35    36    37    38    39
External Moderator
[ Edited ]
assuming this is the Brocade 5100, show as all port are in "ds" = default switch
change to base switch 2 with the command "setcontext 2"
and check with "switchshow" command if any port is assigned in "ls"
to change back to "ds" execute teh command "setcontext 128"
all this operation are not disruptive.
TechHelp24
Antonio, thanks for the quick replies on this...  Yes, the command is from 5100 switch.  On switchshow I see this
- LS Attributes:  [FID: 128, Base Switch: No, Default Switch: Yes, Address Mode 0]
Do I need to run "setcontext 2"  ?  Is this so you release the default switch and switch to base switch?  Is this required so I could disable the VF from this switch?   I wanted to try:
fosconfig --disable vf
What is the sequence of events/commands  that need to happen so I can disable/remove vf from these two switches?
Thanks for your help,
External Moderator
@ddywz
--->>>Do I need to run "setcontext 2"
you need only to do setcontext 2 to check if any port is associated to "ls 2"
from "ds" = default switch execute follow command
lscfg --delete 2 - where 2 is the logical switch you want to delete
then
--disable fv is disruptive, and a reboot is mandatory required.
TechHelp24
when I do setcontext 2  I get the following...
switch_name:FID128:admin> setcontext 2
FID not associated with a switch.
External Moderator
@ddywz
sorry for the confusion, I opened the threads from my smartphoe, and the line was overlapping.
forgot this with the ls
the 2 stay indicated the switch Domain ID
there are no ls created, so you can continue with
TechHelp24
That's what I thought... Thanks for your help.
Since this a a production system and disabling vf requires reboot and paths will be lost and alerts will go out..  I have to schedule this change for another day during the week.
Will report back with results.
Thanks for helping me out today.  Really appreciate your fast inputs.
Super Contributor
Hello,
only one thing..are you sure that you would like to disable VF? In many situation we are enable it once the switch comes to DC. It will help you a lot if you would like to use this feature in future, as reboot on productive environment is always hard thing to do.
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
