Contributor
Virtual Fabric Disable Problem...
Hello All,
I have a DCX I'm trying to disable Virtual Fabric feature on but it appears to tell me I have not delted the default switch yet.
XXX_Lab_DCX-4s:FID128:admin> fosconfig --show
FC Routing service: disabled
iSCSI service: Service not supported on this Platform
iSNS client service: Service not supported on this Platform
Virtual Fabric: enabled
Ethernet Switch Service: disabled
XXX_Lab_DCX-4s:FID128:admin> fosconfig --disable vf
WARNING: This is a disruptive operation that requires a reboot to take effect.
Would you like to continue [Y/N]: y
Please delete all but the default switch before disabling Virtual Fabric.
XXX_lab_DCX-4s:FID128:admin>
When I look at the followin g I have moved all port to the FID 128 which is the default switch id, so there is nothing left to be changed or moved. Is ther something further I need to do in order to remove the feature and delete the default switch?
I tried to run this command te delete (128) which I assume is the default switch - lscfg --delete 128 -force
But then I get this error message:
TRC_Lab_DCX-4s:FID128:admin> lscfg --delete 128 -force
lscfg: Unable to delete the default switch.
FID: 128
Created switches: 128(ds) 2
Slot 1 2 3 4 5 6 7 8
Port
0 | 128 | 128 | 128 | | | 128 | 128 | 128 |
1 | 128 | 128 | 128 | | | 128 | 128 | 128 |
2 | 128 | 128 | 128 | | | 128 | 128 | 128 |
3 | 128 | 128 | 128 | | | 128 | 128 | 128 |
4 | 128 | 128 | 128 | | | 128 | 128 | 128 |
5 | 128 | 128 | 128 | | | 128 | 128 | 128 |
6 | 128 | 128 | 128 | | | 128 | 128 | 128 |
7 | 128 | 128 | 128 | | | 128 | 128 | 128 |
8 | 128 | 128 | 128 | | | 128 | 128 | 128 |
9 | 128 | 128 | 128 | | | 128 | 128 | 128 |
10 | 128 | 128 | 128 | | | 128 | 128 | 128 |
11 | 128 | 128 | 128 | | | 128 | 128 | 128 |
12 | 128 | 128 | 128 | | | 128 | 128 | 128 |
13 | 128 | 128 | 128 | | | 128 | 128 | 128 |
14 | 128 | 128 | 128 | | | 128 | 128 | 128 |
15 | 128 | 128 | 128 | | | 128 | 128 | 128 |
16 | 128 | | | | | | 128 | 128 |
17 | 128 | | | | | | 128 | 128 |
18 | 128 | | | | | | 128 | 128 |
19 | 128 | | | | | | 128 | 128 |
20 | 128 | | | | | | 128 | 128 |
21 | 128 | | | | | | 128 | 128 |
22 | 128 | | | | | | 128 | 128 |
23 | 128 | | | | | | 128 | 128 |
24 | 128 | | | | | | 128 | 128 |
25 | 128 | | | | | | 128 | 128 |
26 | 128 | | | | | | 128 | 128 |
27 | 128 | | | | | | 128 | 128 |
28 | 128 | | | | | | 128 | 128 |
29 | 128 | | | | | | 128 | 128 |
30 | 128 | | | | | | 128 | 128 |
31 | 128 | | | | | | 128 | 128 |
32 | 128 | | | | | | | |
33 | 128 | | | | | | | |
34 | 128 | | | | | | | |
35 | 128 | | | | | | | |
36 | 128 | | | | | | | |
37 | 128 | | | | | | | |
38 | 128 | | | | | | | |
39 | 128 | | | | | | | |
40 | 128 | | | | | | | |
41 | 128 | | | | | | | |
42 | 128 | | | | | | | |
43 | 128 | | | | | | | |
44 | 128 | | | | | | | |
45 | 128 | | | | | | | |
46 | 128 | | | | | | | |
47 | 128 | | | | | | | |
48 | | | | | | | | |
49 | | | | | | | | |
50 | | | | | | | | |
51 | | | | | | | | |
52 | | | | | | | | |
53 | | | | | | | | |
54 | | | | | | | | |
55 | | | | | | | | |
56 | | | | | | | | |
57 | | | | | | | | |
58 | | | | | | | | |
59 | | | | | | | | |
60 | | | | | | | | |
61 | | | | | | | | |
62 | | | | | | | | |
63 | | | | | | | | |
Regular Contributor
Re: Virtual Fabric Disable Problem...
Hi,
you can not delete the default switch.
If you want to disable virtual fabric you have to disable the feature.
You have to perform:
Be careful: Switch will reboot.
Kind Regards
Ralf
Contributor
Ralf,
I did try and disable the feature as you can seee from my post. It still ask me to delete the default switch.
Frequent Contributor
Erm... "Please delete all but the default switch before disabling Virtual Fabric." means "delete ALL switches MINUS the default switch"...
Contributor
There is nothing but the defailt switch (FID128) left. I only tried delteing that just in case, obviously it failed.
Still, the feature won't allow me to disable.
Did you delete the base switch, too? If yes and it still doesn't work, better open a case with support.
Hmm... checked your output again... no bs in lscfg --show...
But if your lscfg --show still looks like above, you should delete the logical switch 2.
Contributor
There is no other logical switch to remove. If you notice it's just the base switch.
TRC_Lab_DCX-4s:FID128:admin> switchshow
switchName: XXX_Lab_DCX-4s
switchType: 77.3
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 1
switchId: fffc01
switchWwn: XXXXXX
zoning: OFF
switchBeacon: OFF
FC Router: OFF
Allow XISL Use: OFF
LS Attributes: [FID: 128, Base Switch: No, Default Switch: Yes, Address Mode 0] -------- >
I honestly think it has to do with the ports configurations on the switch that are still configured, particularly the VE ports I have, even though they are offline.
204 8 12 01cc00 -- -- Offline VE
205 8 13 01cd00 -- -- Offline VE
206 8 14 01ce00 -- -- Offline VE
207 8 15 01cf00 -- -- Offline VE
208 8 16 01d000 -- -- Offline VE
209 8 17 01d100 -- -- Offline VE
210 8 18 01d200 -- -- Offline VE
211 8 19 01d300 -- -- Offline VE
212 8 20 01d400 -- -- Offline VE
213 8 21 01d500 -- -- Offline VE
214 8 22 01d600 -- -- Offline VE
215 8 23 01d700 -- -- Offline VE
216 8 24 01d800 -- -- Offline VE
217 8 25 01d900 -- -- Offline VE
218 8 26 01da00 -- -- Offline VE
219 8 27 01db00 -- -- Offline VE
220 8 28 01dc00 -- -- Offline VE
221 8 29 01dd00 -- -- Offline VE
222 8 30 01de00 -- -- Offline VE
223 8 31 01df00 -- -- Offline VE
Your output says "Created switches: 128(ds) 2" - you don't think it could have something to do with the logical switch 2 being listed directly right after 128, the default switch?
