Anonymous
V5.0.1b firmware
I upgraded our 12000 from 4.2 to 5.0.1b. Web Tools no longer accepts userid and passwords. I'm using IE 6.0. Has anyone else run into this?
Anonymous
Re: V5.0.1b firmware
Yes, I have the same problem with our two 200E switches, have anyone found any solutions fot that ?
Anonymous
I unfortunately have to work with IBM support. They have not found a solution yet.
Anonymous
I found solution, strange but the problem was with the ethernet autonegotiation, when I have connected direct to the switch with cross-over cable everythink was ok, than on my ethernet switch I set up manually speed for the 100Mb/s and Web Tools starts to work.....
Anonymous
I thought you can't make the jump from v4.2.x directly to v5.0.1b without going to at least v4.4.x .
Anonymous
OK, I'm a networking hack. Can you tell me how you set up the PC to do the point to point with the switch?Thanks
Anonymous
Just connect PC and switch with a cross-over cable and setup on PC IP address from the switch network range....
Contributor
Could it be something between the firmware?
Anonymous
Actually it was the way my IE was configured. You can not have a proxy server configured.
