Anonymous
Using nodefind on Brocade 3800 gives syntax error
Using nodefind on Brocade 3800 gives syntax error. Its been few days in my new office., they have a fabirc with all Brocade 3800 switches
when i use nodefind to find host to which switch it is connected in the fabric. it gives me syntax error. How would i be able to find details of the host in a fabric where it is connected. And also why does grep , more commands dosent work on these switches...your help on this is much appreciated.
External Moderator
Re: Using nodefind on Brocade 3800 gives syntax error
--->>> ....when i use nodefind to find host to which switch it is connected in the fabric.
try it with the command "nsshow"
TechHelp24
Anonymous
Don't forget ' " ' characters
sw:admin> nodefind 20:06:00:a0:b8:12:3a:0f
syntax error
sw:admin> nodefind "20:06:00:a0:b8:12:3a:0f"
  010000
1 device with wwn 20:06:00:a0:b8:12:3a:0f }
kind regards,
david
