Turn on suggestions
Showing results for
03-11-2004 02:51 PM
I currently have a switch(6400/2250 firmware, 2.6.1c) that has locked me out from accepting telnet sessions via ethernet. If I configure a fibre channel IP on the switch and then access it via an HBA that has also been assigned a fibre IP, will I get the same responce from the telnet request?
04-06-2004 12:31 AM
is this the message you are getting when attempting telnet connection?if so, you can use web tools to connect to the switch and then disconnect the existing telnet connection.
04-20-2004 01:28 PM
This is what I get. Connection to fswbrc09.qst07 closed by foreign host.
