Anonymous
Using FCIP routers 7500M. VE_Port not coming up
Hi Experts.
I am using a pair of 7500M routers and have done all the configurations. Port is still showing up a G-Port.
Port: ge0
        Tunnel ID 0
        Tunnel Description Not Configured
        Remote IP Addr 172.18.152.32
        Local IP Addr 172.19.24.32
        Remote WWN 10:00:00:05:1e:53:be:fb
        Local WWN 10:00:00:05:1e:54:11:7b
        Compression on
        Fastwrite off
        Tape Pipelining off
        Committed Rate 131072 Kbps (0.131072 Gbps)
        SACK on
        Min Retransmit Time 100
        Keepalive Timeout 10
        Max Retransmissions 8
        VC QoS Mapping off
        DSCP Marking (Control): 0, DSCP Marking (Data): 0
        VLAN Tagging Not Configured
        TCP Byte Streaming off
        Status : Inactive
        Connected Count: 47
________________________________________________
15  15   010f00   id    N4   No_Light    FC  Disabled (Persistent)
16  16   011000   --    --   Offline     VE
17  17   011100   --    --   Offline     VE  Disabled
18  18   011200   --    --   Offline     VE  Disabled
19  19   011300   --    --   Offline     VE  Disabled
20  20   011400   --    --   Offline     VE  Disabled
21  21   011500   --    --   Offline     VE  Disabled
22  22   011600   --    --   Offline     VE  Disabled
23  23   011700   --    --   Offline     VE  Disabled
24  24   011800   --    --   Offline     VE  Disabled
25  25   011900   --    --   Offline     VE  Disabled
26  26   011a00   --    --   Offline     VE  Disabled
27  27   011b00   --    --   Offline     VE  Disabled
28  28   011c00   --    --   Offline     VE  Disabled
29  29   011d00   --    --   Offline     VE  Disabled
30  30   011e00   --    --   Offline     VE  Disabled
31  31   011f00   --    --   Offline     VE  Disabled
     ge0  id    1G   Online    FCIP
     ge1  id    1G   No_Sync   FCIP  Disabled
Pls help!
Anonymous
Re: Using FCIP routers 7500M. VE_Port not coming up
check the licenses if they are in accordance to the manual. If you don't have the full FCIP license you cannot configure over 45Mbit/s as commit rate.
If that is OK check if they can reach each other by using the portcmd --ping command. See manual for syntax.
Otherwise take supportsaves and send that to your service provider.
Cheers,
E
