Occasional Contributor
Urgent help - configdownload issue
I am getting below message while performing config download.
Appl     Primary/Secondary Versions
FOS      v7.4.1a
         v7.4.1a
Switch is disabled now. A production issue can someone help please
configdownload -sftp IP address ,admin,/tracedump/SW1/config280220160451.txt,password
                         *** CAUTION ***
  This command is used to download a backed-up configuration
  for a specific switch.  If using a file  from a  different
  switch, this file's configuration  settings will  override
  any current switch settings.   Downloading a configuration
  file, which was uploaded  from a different type of switch,
  may cause this switch to fail.
  A switch reboot is required for the changes to take effect.
  configDownload operation may take several minutes
  to complete for large files.
  Do you want to continue [y/n]: y
admin@xx.xx.x.xx's password:
Doing configDownload on switch ...
Activating configDownload: Switch is disabled
configDownload: Edge Hold Time (0) is out of range (80..500)
configDownload not permitted
Valued Contributor
Re: Urgent help - configdownload issue
Did you already check the EHT value in the config file that you are trying to download?
