Anonymous
Re: Upgraded 4024 firmware from v5.3.0a to v6.1.0g and now get message
We are IM2
hp_fiber1:root> interopmode
InteropMode: McDATA Fabric
    Default Zone: Off
    Safe Zone: Off
usage: InteropMode ]
       0: to turn interopMode off
       2: to turn McDATA Fabric mode on
           Valid McDataDefaultZone: 0 (disabled), 1 (enabled)
           Valid McDataSafeZone: 0 (disabled), 1 (enabled)
       3: to turn McDATA Open Fabric mode on
External Moderator
Josh
you wrote in the latest reply follow
In the release notes it says that SW_RSCNs for RSCNs generated by attached nodes are not being handled in McDATA Mode this is fixed in 6.2.0a.
Sorry my ignorance but i cannot find in the RN 6.2.0a what you wrote here.
However is this error is know by any old FOS release and this is fixed in 6.2.0a like as you wrote here and you get a RSCN error so i must assume
you have a wrong config or you have a defective parts
Again i cannot find in the RN 620a this fixed or closed defect
TechHelp24
External Moderator
Dear Josh
i found what you mean. This defect was detect in 610 and fixed in 620 and not 620a
Defect ID DEFECT000212416 Technical Severity Medium
Summary SW_RSCNs for RSCNs generated by attached nodes are not being handled in McDATA Mode
Symptom RSCNs are not received for notifications generated by nodes in common zones that are attached to
remote domains.
Risk of Fix Medium Feature: FC Services
Probability High Function: Name Server
Reported In Release FOS6.1.0
with other word if you upgrade to 620 or higher is this Defect solved
TechHelp24
Anonymous
I'm beginning to think that upgradeing to 6.2.0a will solve the problem.  Do you think so also?
Josh
External Moderator
Josh
yes i think same but this defect close the RSCN and i am not sure if your CRC error is caused by this RSCN Closed Defect or better to say i have my doubt that you solve the CRC Problem with this upgrade.
TechHelp24
