Turn on suggestions
Showing results for
03-27-2013 03:59 AM
Hi:
I need to upgrade frimware in SW4016 from v5.0.4.
I think the firmware upgrade process step by step, is as follows:
v5.0.4>v5.2.0>v5.3.0d>v6.0.0b>v6.1.0a>v6.2.2f
I can not update it from the console, I get the following error:
Could not read the Pfile headr.
Firmwaredownload failed. (0x12) Cannot access package list (.plist) file.
Can you please confirm us the commands?
Kind regards
03-29-2013 02:48 PM
when upgrading in the earlier versions of FOS you have to specify the exact path to the extracted firmware image with the /release.plist appended to the end of the path statement. So \v.5.2.0\release.plist
