New Contributor
Upgrade 300E switches
We are currently running Version 7.1.0a on all our switches and would like to find out what the recommened version up upgrade to and also the firmware download location, having trouble finding documentaiton and upgrade paths.... thank you
New Contributor
Re: What is the brocade 300 latest firmware version
We aree currently running Version 7.1.0a on all our switches and would like to find out what the recommened version up upgrade to and also the firmware download location, thank you
External Moderator
@Clive Ainley
- Please don't Open/post multiple question for same inquir.
- FOS download is available with active maintenance contract
- I moving the Thread in correct Forum
TechHelp24
New Contributor
found all the firmware versions and documents from
https://portal.broadcom.com/
Dell Assist Portal
New Contributor
[ Edited ]
----We are currently running Version 7.1.0a on all our switches and would like to find out what the recommened version up upgrade to ---and also the firmware download location, having trouble finding documentaiton and upgrade paths.... thank you
DS-300B?
You will need upgdate in this sequence:
v7.2.x
v7.3.x
v7.4.2d (is the last) but I Think that in the Brocade site just have until the v7.4.2c
External Moderator
@GabrielCosta
--->>>.....but I Think ...
you thinking wrong!
TechHelp24
