Occasional Contributor
Unable to login - maximum number of remote sessions .. reached
Login to the switch for user admin via telnet is not possible due to the maximum number of remote sessions reached. How can the sessions be closed without having to reboot the switch?
In previous versions of the f/w this problem could be resolved by accessing the gui and requesting a telnet session, whereby a popup gave the option to abort the current sessions. This is not possible with the new f/w. We are running firmware 5.3.0d.
The exact message is: "You are unable to login now as admin. The maximum number of remote sessions for user admin has been reached. Please close existing session(s) for this user and try again.
n.b. I know the root password if that is necessary.
Martyn
Anonymous
Re: Unable to login - maximum number of remote sessions .. reached
You can use the "i" command that shows the active process, and then kill the telnet process !
bye
Anonymous
Hi,
you also can run the "killtelnet" command, which will show you who  is logged in the from whihc ip address.
Regards,
Ed
Anonymous
Yes, sure !
Anonymous
I ran into this problem while logging into a DCX switch today.
Sorry! Max remote sessions for login:admin is 2
The "killtelnet" command could not resolve the problem.  Also a "kill" on the "telnetd" or in my case a "sshd" was not possible.
To resolve the problem, I had to login as root and truncate the /var/run/utmp file. (Note: do not delete this file)
I specifically issued the following: cat /dev/null  >/var/run/utmp  .
What seemed to be the cause is an abnormally terminated telnet or ssh session. It left remnants of a session that can be seen using the "who" command but was no longer visible in the output of "i" or "killtelnet" commands.
I am pasting the putty session log for clarification.
user33@sanmgmt-host42:$ ssh admin@DCX001-A
admin@DCX001-A's password:
Connection to DCX001-A closed.
user33@sanmgmt-host42:$ ssh root@DCX001-A
root@DCX001-A's password:
Disclaimer for Root and Factory Accounts Usage!
DCX001-A:root> who
root     pts/0    Nov 19 20:33
admin    pts/2    Mar  9 21:04
DCX001-A:root> i |grep pts
4 S     0  5684  5665  0  75   0 -   734 -      pts/0    00:00:00 sh
4 S     0  7096  5684  0  78   0 -  3440 -      pts/0    00:00:00 i
0 S     0  7097  5684  0  75   0 -   436 -      pts/0    00:00:00 grep
0 R     0  7100  7096  0  80   0 -   557 -      pts/0    00:00:00 ps
DCX001-A:root> killtelnet
Collecting login information....
                   List of sessions (1 found)
______________________________________________________________________________
 Session No   USER     TTY      IDLE     LOGIN@ FROM
     0        root     pts/0    0.00s    20:26  10.44.44.40
Enter Session Number to terminate (q to quit) q
DCX001-A:root> cat /dev/null >/var/run/utmp
DCX001-A:root> who
DCX001-A:root> logout
DCX001-A:root> who
root     pts/0    Nov 19 21:39
DCX001-A:admin> uptime
 22:14:23 up 662 days, 22:26,  1 user,  load average: 0.28, 0.10, 0.02
DCX001-A:admin> logout
