Anonymous
Trunk, add two brocade 300 switches
Hi All,
I am a Newbie to brocade "SAN". I have a quick question regards to adding "interconnecting two brocade300 switches". I need to know
1. Do i need license?
2. What type of configuration is needed for this?
3. Do i need a special fiber port
4. Can i do the same with any other SAN PRODUCT?
Thanks,
/Ikram
Anonymous
Re: Trunk, add two brocade 300 switches
1- Yes you need the Fabric License
2-What do you mean with this question?
3-No unless you need to span more than, say, 300 meters.
4-Yes any other SAN product from the same vendor/brand or if its mentioned in a support matrix.
Anonymous
Hi Dion,
Thanks alot.
1. What Fabric License do i need ? currently i have
*****cQReRSy*******:
    Fabric license
****RSz9b9zU*******:
    Fabric Watch license
*****Sz9b9z*********:
    First Ports on Demand license - additional 8 port upgrade license
******EGCLggB3YWYQBRZmJGrSgBfQ****************:
    Enhanced Group Management license
****A7FAtTB4AQFBLWEJtP******************:
    8 Gig FC license
******GSSEr7CYaNamffZXg**************:
    Extended Fabric license
    Performance Monitor license
    Trunking license
    Adaptive Networking license
    Unknown40 license
Do i need any other license
2. Do i need to configure or add any special ports "F-Port"? and do you know how i can find a guide to do so
4. where can i find a support matrix
Thanks again,
/Ikram
Anonymous
    Fabric license
This should be enough, if not the port will segment and gives a reason as to why is segments.
F ports are for initiators and targets.
ISL's uses E ports. If your port configurations is the default one, an port will automaticlly become an E port if its an ISL.
Support matrices are found in the download section.
