New Contributor
Too many alerts from MAPS
We have Brocade DCX series as well as 5100/65XX switches in our environment  having  FOS   v7.4.1b with MAPS enabled for monitoring.  We receive 100's of alerts everyday. I would like to stop messages which are not critical. Your help is highly appreciated.
Affected Entity:   E-Port 1/5
Rule Name:                        defALL_PORTS_IO_PERF_IMPACT
Condition:                          ALL_PORTS(DEV_LATENCY_IMPACT==IO_PERF_IMPACT)
Current Value:                  [DEV_LATENCY_IMPACT,IO_PERF_IMPACT, 12 ms Frame Delay]
Dashboard Category:      Fabric Performance Impact
Switch Name:                   SWXXXX
Switch WWN:                   10:00:00:27:f6:5a:8f:34
Switch IP:                           192.168.137.6
Fabric Name:                     uninitialized
VFID:                                   126
New Contributor
Re: Too many alerts from MAPS
Attaching File of Switch configs.
Broadcom Moderator
Hi,
the message you are refering to is a FPI message. FPI thresholds can not be changed. Try to investigate why this port is introducing latency as a next step.
TL
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers. All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
Broadcom Moderator
Hi again,
another option if you just want to suppress the messages you could youse the quiet time for messages.
Example:
  1. The clone the defALL_PORTS_IO_PERF_IMPACT to custom rule cust_ALL_PORTS_IO_PERF_IMPACT.
mapsrule --clone defALL_PORTS_IO_PERF_IMPACT -rule cust_ALL_PORTS_IO_PERF_IMPACT
  1. Congiure the custom rule with quiet time. Quiet time can be like 5 mins or 30 mins or 1 hour based on your requirement. Below example to configure quiet time of 5 mins (in seconds)
mapsrule --config cust_ALL_PORTS_IO_PERF_IMPACT -qt 300
  1. Add the new custom rule to custom policy. If the active policy is a default policy, then needs to clone the respective policy too, then delete the default rule and add the new qt rule.
  2. Finally enable the policy.
TL
