Anonymous
Three DCX 8510-8 ,Need to connect with Mesh Topology with 8ICL connection with other DCX (Step by step process/command)
Mesh_3DCX connectivity.JPGI have three DCX 8510-8 ,Need to connect with Mesh Topology with 4ICL connection with one blade to another DCX blade mean One DCX connect to other DCX with 8 connection (4 from each balde), same way with all three dcx,Please let me know step by step process as well as command ,If you need more info please let me know
If any one have doc please send me   suresh0477@gmail.com
External Moderator
Re: Three DCX 8510-8 ,Need to connect with Mesh Topology with 8ICL connection with other DCX (Step by step process/command)
Hi,
I want to ask, who has made ​​this design?
And are the DCX current running with this Mesh Design ?
TechHelp24
Anonymous
Going to new implementation.. I want to know  any manual configuration involve OR as per document automatically configured......
Thanks
Suresh
External Moderator
"iclcfg" command is the main command, fo details refer the Command Reference Manual.
Addtional, in FOS Admin Guide Chapter 19 are some details about ICL.
TechHelp24
Anonymous
Thanks for reply ,Please let me know any issue in this design?
Thanks
Suresh
External Moderator
I'm not sure if this is a issue.
ICL Connection from DCX CR16 Slot 8 Port 4,5,6,7 show a connection to CR16 Slot 8 Port 8,9,10,11 - I have marked with a circle.
I don't know the ICL License you have installed, if ICL is not full Licensed i think the connection must point to Port 0,1,2,3 instead to Port's 8-11
TechHelp24
