New Contributor
Telnet and HTTP block in Brocade
Hi,
We are planning to block Telnet and HTTP in our environment, however these should not be blocked for BNA. Plesae can some one suggest how we can implement the same.
Occasional Contributor
Re: Telnet and HTTP block in Brocade
Hello,
you may go with ipfilter command and clone the default_ipv4  and add rule 1 to specify the IP ( BNA IP) for port 23 (telnet) and 80  (http)to permit , which should effectively deny  all other IPs to  port 23 and 80
Regards
Sushanth
it is a  good practice is to " deny any "  for telnet and http
For BNA you can use https instead of http
Regards
Sushanth
New Contributor
Hi,
Command to block telnet
ipfilter --addrule BlockTelnet -rule 1 -sip any -dp 23 -proto tcp -act deny
My Question is :-
Do we need to put SIP :- as BNA IP , so it will not block the BNA and same for HTTP.
I believe we need to add two rules 1 for telnet and other for HTTP
And what would be the sequence of these rules.. Thanks
yes, have to be  two rules on the same policy with -sip bna ip  -act permit   ( to only permit BNA IP)
Regards
Sushanth
