Anonymous
Technical SupportSave fails in BNA 11.1.3.
When trying to do a technical supportsave from BNA 11.1.3, I get an error that says, " Technical SupportSave Failed. Try configuring the preferred address in Switch-Server Communication in the options dialog to IPv6 and try again."  We are not using IPv6 in our environment yet and have it disabled. Any suggestions?
Anonymous
Re: Technical SupportSave fails in BNA 11.1.3.
Hi Michael,
We have the same problem with BNA 11.1.4 but only for some remote workstations. Did you find out what is the cause of problem?
Anonymous
I suggest checking the IP interface of the BNA server and make sure it is set up correctly .
Firewall on the BNA server is worth checking also to make sure it is not preventing the switch from connecting to the BNA FTP server .
Anonymous
DNS is configured and BNA server accessible by ip or hostname, no firewalls between client and server.
Here what I get in client.log:
2013-02-15 21:48:39,292 INFO  (AWT-EventQueue-2) Profiler: Opening Technical SupportSave
2013-02-15 21:48:46,453 WARN  (AWT-EventQueue-2) com.brocade.efcm.framework.xul.DialogDef: label 'techSupportDialog.availableSwitches.label' not contained in com.brocade.efcm.technicalsupport.client.view.TechSupportDialog
2013-02-15 21:48:46,453 WARN  (AWT-EventQueue-2) com.brocade.efcm.framework.xul.DialogDef: label 'techSupportDialog.selectedSwitches.label' not contained in com.brocade.efcm.technicalsupport.client.view.TechSupportDialog
2013-02-15 21:48:46,453 WARN  (AWT-EventQueue-2) com.brocade.efcm.framework.xul.DialogDef: table 'techSupportDialog.selectedSwitches.table' not contained in com.brocade.efcm.technicalsupport.client.view.TechSupportDialog
2013-02-15 21:48:46,781 INFO  (SwingWorker-pool-1-thread-2) Loading 5,000 events took 48,907ms
2013-02-15 21:48:54,144 ERROR (AWT-EventQueue-2) FTPException occured while checking folder permission
com.enterprisedt.net.ftp.FTPException: Try configuring the preferred address in Switch-Server Communication in the options dialog to IPv6 and try again.
at com.brocade.efcm.ftp.common.util.FTPClientUtil.verifyIpAddressCompatibility(FTPClientUtil.java:661)
at com.brocade.efcm.ftp.common.util.FTPClientUtil.init(FTPClientUtil.java:305)
at com.brocade.efcm.ftp.common.util.FTPClientUtil.<init>(FTPClientUtil.java:118)
So what folder permission it is trying to check?
Anonymous
Can you check the IP / interface of the BNA server is set up correctly .
Client/Server IP in " Server > Options ( under software configurations ) can be a place to correct the interface chosen for the BNA server . OR on the server itself you can launch the " Network Advisor Configuration "  , i.e < install > \ bin \ configwizard.bat
