Anonymous
Tapes and Disks over Single HBA
I have several Sun servers each with two Qlogic HBAs. The two HBAs in the hosts are attached to separate fabrics (Brocade Silkworm 3800s). The disks are Hitachi and the servers are in zones for the appropriate LUNs. Now we are ready to add tape drives from STK into the mix. We were planning to use the same HBAs for both disk and tape access. We are planning to use Veritas Netbackup.
Anonymous
Re: Tapes and Disks over Single HBA
We are currently running a similar environment, although we are just now adding Sun boxes in the mix.Hope this helps...
Anonymous
The way that rslinger zones is actually pretty good practice and also fairly common. The single server zones with Windows is mainly due to the fact the most versions of windows out there are not SAN aware. This means, they will go out and try to grab anything they see and think it is their disk (or tape).Keeping disk and tape separate via zones is also good practice.
Anonymous
We use separate HBAs for tape and disk where the vendors of the tape or disk are different. Otherwise we get support problems. As we use StK tapes but not their disks, we almost always have tape on a separate HBA. Also you cannot set the driver parameters ideally for both on one HBA. Server vendors also do not like you to buy 3rd party HBAs - worst case you may find server vendor and storage vendor have no HBAs they both support We usually zone one-HBA per zone to multiple targets. But on EMC Celerra we are using one zone per target tape drive. Seems to help, but unusual.
Anonymous
We have 30 HPUX boxes and over 10 Wintel (Proliant and HP netserves) using the sames HBS to access both disks and tape drives in a lan-free backups architecture.HTH
Anonymous
It is very interesting reading all the associated mails. Many ways to skin a cat, I totally agrre with all the mails, because it really does depend on your setup, however...Sorry
Anonymous
Guys,Thanks
Anonymous
All vendors will tell you to use an HBA for disk and an HBA for tape. They want to sell you more hardwre. SCSI is SCSI. Let er rip...
Anonymous
True, but some tape vendors are starting to introduce HBA settings that may conflict with settings optimized for disk.
Anonymous
I think it's safe to say that best practices dictate that disk and tape not be mixed on the same HBA. However, in most cases, it will work - we've got our NetBackup master/media server using the same HBA for both but our two newer media servers have the traffic on separate HBAs. We've got the new HBAs for our master on our TODO list though.
